Old 10-08-2016, 02:36 PM   #1
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
New Pig Tails
Kind of a stupid question . . .
Is there supposed to be a rubber washer or gasket inside the "cup"?
When it is screwed onto the tank and I open the valve, I smell gas.
It's not coming from the other end . . . I can smell it directly at the tank connection (and I've tested it at the other end).
(these are brand new)
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-08-2016, 02:50 PM   #2
2007 22' International CCD
I don't have access to mine, but I think there is supposed to be an O ring near the opening in the cone. If there is a shallow groove there, it's missing. Hard to tell from picture.
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 10-08-2016, 03:04 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Looked at mine. The o-ring is in the tank valve.
MICHAEL
Old 10-09-2016, 04:23 AM   #4
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
I went out and looked, and there is a pressed in rubber ring in the Tank's Valve.
And I'm guessing they are "weathered" and a little dried out . . . actually I'm not guessing at all - they are.
And this is probably something only a "tank certifying person" can address . . . (?).
Old 10-09-2016, 05:58 AM   #5
AWCHIEF's Avatar
Images: 33
If they are full service where you get your tanks refilled should be able to replace the o-ring for you if you are unable to do it yourself.
MICHAEL
Old 10-09-2016, 02:58 PM   #6
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Having a hard time finding the actual "part".
Or anyone that sells it.
So I assumed it wasn't something you can "swap out" easily.
I guess I should go un-fasten the tanks and put them on the work bench so I can inspect closer / better.
Old 10-09-2016, 03:28 PM   #7
AWCHIEF's Avatar
Images: 33
I just called my local Ace Hardware. I ask if they had the O-rings used in the propane tank OPD valve. Answer, yes. 96 cents for a package of 6.
Called Blossom Gas my local best price refill, answer, yes. No cost.
MICHAEL
Southwest Pack Rats... with tails Ray Eklund Boondocking 27 02-22-2016 11:00 AM
Affordable source for repro Bargman 99 Tails? ST131 Lights - Interior & Exterior 0 11-22-2009 09:29 AM
October 12 Fall Color Rally - Pig Roast N IL S WI 2007 flamingo-kid1 Forum Rallies & Meet Ups 138 10-25-2007 06:33 PM
herky pig Herky Pig Member Introductions 4 03-21-2006 10:11 PM
Spokane's Pig Out in the Park Karyn Off Topic Forum 2 08-30-2005 09:51 AM
