Old 02-22-2015, 02:59 PM   #1
cclaybrook's Avatar
1977 31' Sovereign
Fayetteville , Arkansas
New Owner of '77 Sovereign
My family recently purchased a 77 31' Sovereign. Overall it's in pretty good shape, however, I can't get the furnace to work. Of course, the only page missing from the manual is page(s) 9-3 & 9-4 and the one I need. If anyone has these, I would most certainly appreciate a copy.
Anyone have any troubleshooting tips? It's a Suburban 30. Everything (4 wire terminal) seems to be connected. I have noticed a red (or pink) wire with black stripe paired with a yellow wire in the furnace/oven cavity that is not connected to anything. Any ideas what these go to? I can't find anything on the wire diagrams.
I have ordered a Hunter thermostat (recommended in another thread) since the one installed complete fell apart while checking to make sure it was connected.
Chadd
Name:	ImageUploadedByAirstream Forums1424642328.551167.jpg
cclaybrook is offline   Reply With Quote
Old 02-22-2015, 05:01 PM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
It can take a while for propane to get to the furnace. Can you light your water heater pilot?
4RXLA is offline   Reply With Quote
Old 02-22-2015, 05:10 PM   #3
cclaybrook's Avatar
1977 31' Sovereign
It is still winterized so haven't tried lighting water heater yet.
Old 02-22-2015, 06:50 PM   #4
4RXLA's Avatar
Images: 33
On my 77, the furnace fails to ignite until all the air is purged from the gas lines. The water heater is the end of the line and takes the longest to light. Lighting a burner on the stove helps to get the gas flowing. It could take up to a half dozen or more tries before the furnace ignites. Once the gas is in the lines mine fires up normally.
Old 02-22-2015, 07:14 PM   #5
cclaybrook's Avatar
1977 31' Sovereign
Thank you much! I will give that a try.
Old 02-22-2015, 07:28 PM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
PM your address to me and I will send a hard copy the pages from my 78 OM. I also have all the literature for every appliance that came with the Sovereign including a complete schematic for the Motorola Radio. It can take a while for the line to purge.
Welcome, and let me know if I can help.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 02-23-2015, 12:12 PM   #7
1977 31' Sovereign
Lynnwood , Washington
1) Make sure propane tanks are full and propane lines are completely purged of air. To assist with purge, light all propane appliances; stove, water heater.
FYI - Propane regulator may need to be replaced. Propane pressure beyond regulator should be around 7 psi. Furnace won't ignite unless it is. Remember, the furnace requires far more propane per unit of time than other gas appliances.
2) If your furnace has an igniter, make sure batteries are fully charged and all cells test good. I found this out the hard way. Furnace wouldn't light because batteries were weak.
BTW - I replaced my Suburban furnace about 15 yrs ago. Mine has an igniter.
Tom
TomKirk is offline   Reply With Quote
Old 03-05-2015, 12:50 PM   #8
Sun Rae
jack9443's Avatar
1977 Argosy 28
Lewisburg , Tennessee
My pilot lights and flickers like air blowing in chamber stays till the unit calls for gas then pilot goes out
jack9443 is offline   Reply With Quote
Old 03-05-2015, 03:13 PM   #9
1976 31' Sovereign
Oswego , Illinois
I had same prob. regulator was bad not enough pressure replaced, also propane tanks at 1/2 full reg. would show empty causing water heater prob. after replace reg prob. fixed. Check other threads as there is some thing about valve on tanks not letting propane flow.
sovereign
NEW OWNER of One Owner 1972 Ambassador 29 foot Mrwaterway Member Introductions 11 11-20-2009 12:53 PM
New 72 Sovereign owner in Washington St. Tom Mc Member Introductions 1 02-26-2007 09:08 PM
Almost A New Owner of a 1977 Sovereign jrk247 Member Introductions 21 09-01-2006 10:48 AM
New owner of '77 Sovereign Tim Axles 15 11-02-2004 07:46 AM
New '84 29' Sovereign owner needs help jtwilburt 1984 - 1989 Sovereign 4 10-11-2004 07:12 PM
