Old 03-07-2014, 04:11 AM   #1
1966 22' Safari
tucson , Arizona
new LP lines
Newbie here! Dumb question on the way......I'm restoring a "66" Safari and wonder if I should run new LP lines under my new floor and not under the belly pan. Also, instead of copper lines why not the LP rubber ones? Aside from being able to get to them down the road. Frankly, exposed LP lines connected to my belly pan seem like problem waiting to happen.
1966air is offline   Reply With Quote
Old 03-07-2014, 05:58 AM   #2
SteveH's Avatar
Common Sense , Texas
There's a reason those lines are run under the belly pan and not inside of it, and that is the code as I understand it. The code says there will be no connections other than the terminal connections inside the trailer. And, if the lines are inside the belly pan, a leak in a connection could accumulate in a low spot and if/when it got ignition it would be like a bomb. Besides, you would have to remove the belly pan to check connections, and to get to any shut off valves.
I understand wanting to simplify thing, but think yours is a bad idea.
Regards,
Steve
Old 03-07-2014, 06:00 AM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I may be wrong but I believe there is a 'code' to follow. Like building codes. As far as LP gas lines, other than the final connection at the appliance, all fittings (T's and shut-off valves, etc) must be outside the trailer. Less chance of any leaks filling the cabin. I'm not sure of plastic lines.
Ask someone who restores trailers. Like Colin Hyde. He is here on the forums.
Either way I would install a LP detector in your unit.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-07-2014, 06:21 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yes.
ANSI/NFPA 1192 covers the requirements for RVs:
Venting requirements for propane appliances are specified where necessary.
Propane piping sizes are required to ensure a propane supply that provides for proper appliance performance.
Over fill protection devices (OPD) are required on all installed propane containers.
Propane line routing and accessibility - all joints in propane lines must be accessible for periodic leak testing and repair. Lines may not be installed in spaces where a nail or screw could pierce the line.
Fuel burning appliances must be listed for RV use and labeled by a nationally recognized testing agency that has found the product to be suitable for its intended use.
Sealed combustion and direct venting to the outside is required for all propane appliances, except for gas ranges, to provide for a complete separation of the combustion chamber from the interior atmosphere.
Each propane system must be tested upon final assembly to determine proper leak-free performance.
I've highlighted in red the applicable criterion that requires you to put the lines under the belly pan and not inside the belly pan. The quote is from an RVIA summary of ANSI/NFPA 1192, and is not complete. You may want to go to your local library and look up the standard for yourself to find out all of the requirements applicable to your task.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-07-2014, 11:43 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Keep them outside the belly pan so you don't blow yourself up if there's a leak. Some people sleeve the lines with PEX or other flexible material for protection from gravel and other road hazards.
Copper line used for LP will last for decades if it is not physically damaged while rubber hose has a limited life (10-20 years tops). As a result, hose should not be used anywhere where it cannot be readily inspected and replaced.
Old 05-09-2014, 06:48 AM   #6
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I have seen a copper line with a yellow plastic cover used for gas lines in homes. they use yellow so it easy to spot and follow under a dark house. That would be the best stuff to use as the plastic can help protect the copper from rock or stuff that can kick under the AS going down the road.
That one of the things you do every so often is to have a nice bright flashlight and bend down and look under the rig to check the line, say after a good bit of traveling or if you happen to see debris on the road while traveling.
but YES keep in under belly pan and check .
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
Timeshare owner/user since '99
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 05-09-2014, 07:15 AM   #7
1973 25' Tradewind
Augusta , Georgia
I do like that suggestion. The creative individual could use short pieces of alternating clear, blue, and red.
One a more serious note I seen the corrugated stainless steel tubing at the local home center and was considering this (as suggested in another post). Any experience with that. Also waiting on hearing what the "rock stars" suggest.
Looking at the VAP index episodes 114, 124, & 132 discuss LP lines. One could listen to these or immortalize yourself and call/email in.
DGJackson is offline   Reply With Quote
Old 05-09-2014, 07:28 AM   #8
SteveH's Avatar
Don't know for sure, but I would be concerned about corrosion from dissimilar metals by covering copper with stainless steel. Some sort of plastic or rubber would be better IMHO.
Regards,
Steve
Old 05-11-2014, 07:50 PM   #9
carl2591's Avatar
2005 31' Classic
the corrugated SS lines are nice for sure but they are a bear to deal with.. always wanting to roll up on you. if you can get it rolled out and sorta bend back a bit to take the factory rolling out of it that is a great product. hard a hell to crush/dent, unlike copper, and has a nice protective covering on as well. it might be more costly compared to Copper stuff but more substantial for sure.
The connectors are a snap to use just read the book in the store to get correct cutting procedure.
I was in local lowes and a 25ft roll of 3/8 SS runs $39.00. Not all that bad. was looking at copper 50ft HVAC roll of 1/2" with capped end and nitrigon filled was $90.00 so the SS was a better deal.. go figure.
Carl, Raleigh NC
Old 05-11-2014, 08:28 PM   #10
1974 Argosy 20
Kooskia , Idaho
I don't believe that the corrugated SS is approved for RV's. I know the short flexible corrugated lines you can get in the stores (usually yellow) are not legal. They are limited in their flexing to very occasional use, like a range which needs to be moved out for service etc.
Airstream is still using copper, which is very expensive. They do protect it in a PEX sleeve in some locations. But then, we know Airstream still uses wood floors.... grin.
Old 05-11-2014, 08:41 PM   #11
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Do NOT use corrugated gas lines on your RV!!!!! They will not survive the flexing an RV encounters traveling, and will end up leaking. RV code requires copper pipe and flare connections. Buy a good flaring tool and learn how to make flare connections. It's really not that difficult.
I protected all the gas lines under our trailer with pex. After seeing how much damage was done to the original gas lines under the trailer, it seems like cheap protection.
Chris
Broken gas lines Jenturnr LP Gas, Piping, Tanks & Regulators 4 02-01-2012 08:39 PM
Hydraulic brake lines Bandits Brakes & Brake Controllers 2 01-17-2012 07:17 PM
Easy water removal from lines..worked 4 me Jim & Mitzi Winterizing, Storage, Carports & Covers 6 01-03-2012 07:20 PM
Before I go putting gas through lines?? Mrcrowley LP Gas, Piping, Tanks & Regulators 9 10-04-2011 07:12 AM
LP Gas lines betsy LP Gas, Piping, Tanks & Regulators 6 05-01-2011 06:46 PM
