Join Airstream Forums Today
Old 07-10-2006, 04:58 PM   #1
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
Unhappy New LP gas tank - no purge - blues
Okay, so i get my new Argosy and it has old tanks but they have gas in them. So rather than have to deal with a OPD finagle on the road I purcahsed a new tank at a RV store here. Upon asking a U-Haul store to fill it up the attendant said it only took 5 gallons. Not knowing whether or not that was good, I paid and departed on a trip. I don't think that he purged it. I used up one of the old tanks while on the trip and all of the propane stuff worked fine to that point. After switching to the new tank, the stove worked but with a lot of yellow flame and the hot water wouldn't work at all. So - i think i can hook up the other old tank that sitll has gas and everything will function again. The question is, how do I get my new tank straightened out? Thanks
flitzwhopper is offline   Reply With Quote
Old 07-10-2006, 05:02 PM   #2
pattyo's Avatar
1985 25' Sovereign
South Berwick , Maine
Images: 11
Just take it to a propane station and they can purge it for you (just did it for my mosquito magnet).
WBCCI # 4933 New England Unit
Tin Can Tourists Vintage Club
pattyo is offline   Reply With Quote
Old 07-10-2006, 05:08 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
You should have told the U-Haul attendent that it was a new tank, and they would have purged it, for a small fee. Purging takes about 1 to 2 hours, to do it right. It involves filling the tank with a small amount of propane then bleeding it out and refilling about five times. Some tanks come purged with nitrogen from the factory, so they do not need propane purging.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 07-10-2006, 05:17 PM   #4
1976 Argosy 24
Tempe , Arizona
thanks pattyo... you think that not having used any of the 5 gallons in it will be a problem? Thanks
Old 07-10-2006, 05:21 PM   #5
pattyo's Avatar
1985 25' Sovereign
Images: 11
Shouldn't be a problem having gas in it. I have had a few tanks purged but never went through the process the way Pick has. They've done it for me as part of the fill and never charged me. Not sure why it's different for me than Pick but he seems to know his stuff.
Old 07-10-2006, 05:32 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
my propane guy just attaches a vaccum pump to it and runs it down to zero.
5 bucks is the going fee for a purge in these parts.
i agree they should have caught it before it was filled.
john
you call them ferrets, i call them weasels.
Old 01-19-2012, 09:18 AM   #7
RR , British Columbia
Images: 13
I will bump this as I am sure there are new members that it might benifit.
As explained in the above posts, a new tank must be evacuated before filling with propane.
The same applies if the valve has been opened to the atmosphere before filling.
I have seen questions about venting tanks before polishing.
Never vent a propane tank unless it is being discarded, as it will have to be properly prepared before it can be refilled.
Dave
john
Old 01-19-2012, 10:20 AM   #8
2000 25' Excella
Moraga , California
I don't believe this is accurate, at least not in California, and laws pertaining to propane tanks may well be Federal in nature (I would suspect so (DOT)).
It is my understanding that prior to about 10 years ago, propane tanks were factory-filled with an inert gas for pressure testing and transportation, such as nitrogen, and that had to be purged prior to filling, otherwise a portion of the "filled" tank would be compressed nitrogen (not flammable). While normal atmospshere is nearly 80% nitrogen already, the pure nitrogen-fill would eliminate the other 20% (actually 22%), including oxygen. In other words, a 100% nitrogen-filled tank would have to be purged in order to a full tank of propane.
Today, and for the past several years, propane tanks are factory-tested under vacuum, i.e., they have negative atmospheres at the factory for testing purposes, and are transported that way. These tanks do NOT need to be purged, unless the tank valve has been opened and the tank has been allowed to fill with atmosphere.
Kamiak is offline   Reply With Quote
Old 01-19-2012, 10:31 AM   #9
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
Interesting. My tanks and trailer are new and were filled before I picked it up. Seem to work well so far (at least the first tank). I understand the "tank exchange" suppliers are to be avoided. Is that true? Of course I would rather not trade my brand new tanks for beat up used ones. What are others experiences?
Rich of SCal is offline   Reply With Quote
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
