Old 09-20-2015, 04:59 PM   #1
1968 24' Tradewind
cloverdale , British Columbia
New Holding Tanks
Im planning on having new black and grey water tanks made up and was wondering if putting the drains on the bottom of the tanks instead of the sides is a good/bad idea? Any thoughts?
cregu1 is offline   Reply With Quote
Old 09-27-2015, 07:08 AM   #2
1967 22' Safari
Space Coast , Florida
Hello, I removed the leaking black tank from our '67 Safari '22. I fabricated a bracket to hold a black and gray tank. I bought the tanks from Vintage TS. The tanks are small, 8 gallons each, but we spend 99% of the time in full hook up campgrounds. Now that we are self contained, we can use the water on the road and non full hookup spots.
As to placing the drains on the bottom of the tank, is there enough room in the chassis to have the plumbing below the tanks? I'm not familiar with your frame, however, ours is approx 8" deep. This is what limited us to the small tanks.
Sam.
SamIam427 is offline   Reply With Quote
Old 09-27-2015, 04:41 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I put our gray tank drains on the bottom for a couple of reasons. One, I think it drains the tanks more completely, although 1/8" of water left in the tanks won't cause any harm. Two, it let me run the drain lines under the belly pan and easily keep a slightly downward slope to the dump valve and sewer connection without having to modify any frame members. After 4 years of travelling, we have had zero issues with the drain lines under the belly pan. But, we don't winter camp either.
Chris
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
Mounting New Holding Tanks dbj216 Waste Systems, Tanks & Totes 7 01-21-2014 06:28 PM
New holding tanks & monitor Sys VeggieBullet Fresh Water Systems 3 10-27-2011 07:50 PM
How To Test Holding Tanks hex Waste Systems, Tanks & Totes 1 11-19-2002 02:38 AM
