Old 01-16-2013, 03:35 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
New Flame in Oven (???)
Well, here I am - making some pot pies in the oven...it say preheat to 400. So, but a new sound happens---POOF! - then I look inside and to the right side and near the wall of the oven is another flame...burning right along with the pilot and burner. Can you see it in the photos? And what am I up against this time.
ID:	176831   Click image for larger version
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 01-16-2013, 05:20 PM   #2
richinny's Avatar
2011 34' Classic
that might be a broken gas line. shut it off. i'm looking for a related thread.
Ricky
Old 01-16-2013, 05:25 PM   #3
richinny's Avatar
2011 34' Classic
list of related threads:
broken gas line oven - Google Search
Ricky
Old 01-16-2013, 05:49 PM   #4
1970 27' Overlander
I did turn it off --let it cool off and then took a flash light and shined it back to the area that was flaming ....I have never noticed it doing that before either. But it was happening just to the left of that flat head screw you see.
ID:	176836   Click image for larger version
Old 01-16-2013, 06:29 PM   #5
richinny's Avatar
2011 34' Classic
it would help if you post a make and model number of the oven. i don't have knowledge to advise you but others here do.
Ricky
Old 01-16-2013, 07:45 PM   #6
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I believe what you are seeing is the heater pilot. It ignites the oven burner tube.
I've watched the process in mine. On demand, the standing pilot ignites the larger heater pilot. There may another thermocouple, I don't recall. In 15 seconds or so the burner gas valve opens and whooosh.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-16-2013, 11:08 PM   #7
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Looks like its leaking a little back against the wall. It doesn't look good.
SuperTrouper is offline   Reply With Quote
Old 01-17-2013, 04:04 AM   #8
1970 27' Overlander
I will start asking around here in town about who can just actually stand there and see first hand whats going on. After a while it stops doing it...but still- it does not look right.
Old 01-27-2013, 06:32 PM   #9
1970 27' Overlander
So far it looks like it needs a good cleaning..may be soot build up on the pilot area. OK - so if I want to clean these items...whats good for this? A toothbrush and some....
Or shold I load my compressor and bring an air hose inside with a blower fixture ? The pilot light itself burns bright yellow mostly and that is when the oven temp has been set. When it is not in use - it burns blue.
Old 02-28-2013, 10:37 PM   #10
1970 27' Overlander
Well upon looking closer at this oven, The name on the front is 'AIRSTREAM custom'. I did not find any serial numbers near the door (not unless it was against the wall). But this time I took this photo- and drew a circle around where the flame was coming and going whenever it wanted to. You can almost see the scorch from the flame.
Old 03-01-2013, 06:47 AM   #11
dznf0g's Avatar
Oswego , Illinois
I think Ricky is right. That is not normal IMO. I think you have a cracked gas line. I would not use it and turn off the pilot until that section of line can be examined on the bench and replaced.
-Rich-
Old 03-01-2013, 07:07 AM   #12
Cracked manifold.
I concur with Rich. Looks like the manifold is cracked and should be repaired/replaced before using.
Old 03-01-2013, 07:08 AM   #13
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I would take the stove to an LP gas distributor and have them check it out.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
