Old 08-26-2007, 04:40 PM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
New Aluminum LP Tanks
I have been considering replacing Lucy's OEM steel 30# LP tanks with a Pair of new aluminum tanks. I am looking at the Worthington 40# tanks. What I'd like to do is polish them and run without a cover for a little more vintage look on a late model Safari. I realize that going to 40 pounders will increase my tongue weight, but the added capacity would be worth it.
I realize that this conversion will cost me about $500, but I think the look will be worth the price. Am I missing something from the technical end?
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 08-26-2007, 04:58 PM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Having upgraded from 30s to 40s with my Classic I can tell you what to look for.
The cover is too short but that is not really a problem. It will just sit a little high.
The threaded rod that hold the tanks in place is too short. It will have to be replaced.
You flex should be long enough. try it. the new tanks are about three inches taller. They are the same dameter.
The regulator will have to be relocated. There should be two sets of holes in your bracket.
If anyone is interested in upgrading from 20s to 30s I have a piar of 30s for sale!
Michelle TAC MT-0
Sarah, Snowball
Old 08-26-2007, 05:41 PM   #3
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
aluminum tanks
I'll buy your tanks!!!!
I will PM you.
Greg
Greg, Ashley, Olivia, and Jane Ashley
AIR # 13681
gparker is offline   Reply With Quote
Old 08-26-2007, 05:54 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Do you really need that much propane. I go out every month for a 3 day weekend and only use around 30 pounds a year. Maybe because I do not use the furnace very much.
Richard
Old 08-26-2007, 06:01 PM   #5
moosetags's Avatar
When we were at Yellowstone and Glacier in May, we were using the furnace quite a bit. When it's near or below freezing the heat pump is weak. On our six week trip, we filled three 30# tanks. We are also considering a Yamaha Generator with a propane conversion, and could probably use the increased LP capacity.
Old 08-26-2007, 06:11 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
If you run your furnace, it would make sense. When I switched from 30# steel to 30# aluminum the new tanks were a few inches taller. The verticle bar had an extra hole that was perfect for the new height. I also had to modify the bar across the top because the lip of the top of the tanks is different also. If you go 30# to 40# you will have to replace the verticle bar and maybe modify the propane line from the regulator to the trailer.
Once you polish the tanks, you will not want to put the cover on again. They are just too nice to look at.
Richard
Old 08-26-2007, 07:15 PM   #7
When it gets cold I was filling a 30# tank every three days. 40s I was down to once a week. I understand his rationale.
Michelle TAC MT-0
Sarah, Snowball
Old 08-26-2007, 07:23 PM   #8
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
So.... another 10# will increase the usable capicity an additional 4 days?
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 08-26-2007, 08:00 PM   #9
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hey, if anyone in the NW wants two 40#'s that just need new OPD's - REAL cheap, I'll let you know where they are. I passed on them this weekend, just too big for our needs.
Marc
Old 08-26-2007, 08:35 PM   #10
additional 20lbs of propane between two tanks. 30# lasted for about 3-4 days. additional 30% per tank that gets me to 6-7 days. I can go 10 days before I get worried. That is the Furnace and water heater going on propane.
Michelle TAC MT-0
Sarah, Snowball
Old 08-26-2007, 08:52 PM   #11
peegreen's Avatar
I'm still missing the math; how does 30% more propane double your time between refills?
WBCCI 24291
New England Unit
Old 08-26-2007, 09:01 PM   #12
Girl Math
It is girl math. If I can save 20% at a sale then I can save 40% by spending twice as much.
I doesn't really double it. I can get two or more days from a single tank depending on the weather. Additionally i am not in as much of a hurry to get it filled since I have more reserve.
Michelle TAC MT-0
Sarah, Snowball
Old 08-26-2007, 09:40 PM   #13
moosetags's Avatar
Makes sense to me.
Old 08-26-2007, 09:43 PM   #14
2002 19' Bambi
Lafayette , California
We spend much of September in West Yellowstone and I can attest to the rapid use of propane when the temperatures drop to well below freezing. Our two 30# tanks give us about the same time span for our 19' as thecatsandi indicates for her trailer. No, I have not done the area vs. volume calculation, but a longer trailer could easily need 40# tanks to make it so you do not think you need to fill a tank every couple of days. We switched to aluminum tanks (from Vintage Trailer Supply, of course) several years ago and, although not polished, they are a pleasure. Lighter and the top lip/handle area is much more friendly on the hands. The increased height of the Worthingtons made it necessary to fabricate a new retention bar.
Tim A. is offline   Reply With Quote
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
