Join Airstream Forums Today
Old 10-13-2011, 11:44 AM   #1
Maggiefoss's Avatar
1972 25' Tradewind
Danville , California
Need replacement W/H for '71 airstream
Hi, I need to get a new water heater for my 25 airstream trade wind. Do they only come in a gas model, or do some operate also when plugged into electricity?? i know most have an electronic ignition. Does anybody have a great source for parts. I know of outofdoors mart and inland rv in SoCal. Also, what do you think I'll have to pay to get a new one installed?? Ballpark figure of course!!
Maggiefoss
Maggiefoss is offline   Reply With Quote
Old 10-13-2011, 11:53 AM   #2
Ganglin's Avatar
1971 27' Overlander
Gahanna , Ohio
Images: 13
This is the one we installed - and the least expensive place we found to order it. This is a gas/electric model.
Atwood RV Water Heaters
GARY
Charter Member - NOVA
WBCCI - 5308
INFORMATION AT: http://www.campnova.com/
Old 10-13-2011, 12:05 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
I got my Suburban NT-24SP furnace from Palomino Parts: 1047 E M86 - Colon, MI 49040 - 800 297 5830, I think it was under $300.00
They ship.
See what my trailer cost to restore at:
http://www.airforums.com/forums/f348...ml#post1050484
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 10-13-2011, 03:06 PM   #4
Splitrock's Avatar
1976 31' Sovereign
Sioux Falls , South Dakota
+1 -----------> Palomino Parts
http://img.photobucket.com/albums/v1...g?t=1278182564
Old 11-26-2011, 11:53 PM   #5
AirHome's Avatar
1973 29' Ambassador
San Diego , California
Ganglin, you should know that during my online research I found that the model # 94186 atwood water heater you're recommending was recalled by Atwood for an internal gas leak problem. This online vendor shouldn't be selling this at all!
Here is the recall details.
Atwood Recall Campaign 08E040000 EQUIPMENT | AutoMD
AIR HOME - 73' Ambassador International
Remodel blog: Air Home
Work: http://www.emaxaction.com/
AirHome is offline   Reply With Quote
Old 11-27-2011, 05:54 AM   #6
Ganglin's Avatar
1971 27' Overlander
Gahanna , Ohio
Images: 13
Thanks for posting this. I'd presume what they are selling today was mfg. after June 2008 - but it never hurts to call and ask them first. I'll have to check mine just to be sure though - it only impacted 1,731 units built between May 20 and June 9 2008. That's a pretty small window over 3 years ago. But, better safe than sorry as they say. Thanks again - appreciate the heads up.
GARY
WBCCI - 5308
Old 11-27-2011, 06:01 AM   #7
1969 27' Overlander
Albuquerque , New Mexico
Atwood is the way to go.
Replace with same size (gallon for gallon) and it'll fit in the same opening.
Make sure you install a "leak-pan" under the new water heater (what was AS thinking?).
Combination gas/electric has the advantage of using shore power instead of propane, when convenient. They use quite a lot of propane. Make sure your electrical system can handle the additional 1500 watt load.
If you can't do it yourself, have an RV shop install it for you. They'll probably want to sell you one from their stock, though.
The only thing I didn't like about the new Atwood is they don't offer a chrome (or aluminum) exterior cover. White only. There's a marketing potential!
Ed Glenn
edglenn is offline   Reply With Quote
Airstream Rental for Airstream Owners ONLY jverduzco Airstream Lifestyle 33 10-27-2011 03:06 PM
NEW: 5th Wheel Airstream Airtrekker Boondocking 28 08-10-2011 01:09 PM
