Old 05-06-2004, 09:34 AM   #1
Need new LP tanks
Hi I am the new owner of a 1965 Globe Trotter. This is my first trailer. It came with out tanks or regulator. When calling a tank supplier they had questions I could not answer. What size tanks do I need? and what type/size of regulator?
Any advise.
Bob912 is offline   Reply With Quote
Old 05-06-2004, 09:44 AM   #2
Diesel Pusher's Avatar
tanks
I just bought 2 30 # tanks for my rig. They are the plain white ones that I plan on painting. I paid about $95 a piece for them. The regulator was about $160.
1977 A/S Excella 500, 31 foot
2001 2500 HD D/A 4X4, Ext. cab, Victory Red.
Diesel Pusher is offline   Reply With Quote
Old 05-06-2004, 11:34 AM   #3
What size or type of regulator did you get?
Old 05-06-2004, 11:48 AM   #4
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
try posting here: http://www.airforums.com/forum...splay.php?f=20
or better yet, here: http://www.airforums.com/forum...play.php?f=287
and keep it short but informative in the subject line:
"lp tanks for 65 Globetrotter?" will probably generate the most fruitful responses.
mtpalms is offline   Reply With Quote
Old 05-06-2004, 08:04 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Do a forum search for "aluminum tanks" or "Worthington". The aluminum is lighter and one of the searches will line you up with a vendor that some forum members have received good prices from. I'd say 30 pounders should work.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-06-2004, 08:07 PM   #6
greg176's Avatar
Gabriola Island , British Columbia
Try www.airstreamdreams.com .
greg176 is offline   Reply With Quote
Old 05-06-2004, 08:33 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bob
where ya located? just bought a spare 30 lb cyl. for my trailer.
here in the midwest they run about 60 bucks each.
john
you call them ferrets, i call them weasels.
Old 05-26-2004, 03:43 PM   #8
minkus's Avatar
The important question is "what are you going to be doing"
Are you going during cold weather and need heat, or nice weather without?
Are you just doing weekends, or for weeks at a time?
Are you going into the wilderness, or will you be near town?
Will you use hook-ups and use your electric power, and their showers?
In other words, how much gas will you be using, and how far will you be away from a refill?
On our construction job site during the coldest of the winter, hooked to a 170,000 BTU space heater, one 4-5 gal (30lb?) tank will last quite a long time.
minkus is offline   Reply With Quote
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 06:47 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
