Old 08-22-2016, 12:47 PM   #1
2013 16' Sport
Boulder , Colorado
Need help, water heater diagnostic
HI, my water heater ignites with a large flame coming out of the big tube, not a nice hissing flame through the small tube. Here is a video of what happens when it ignites.
https://www.dropbox.com/s/7hfdr970pa..._1595.MOV?dl=0
Is this an easy repair? Thanks for any help!
CQ
Seecue is offline   Reply With Quote
Old 08-22-2016, 02:11 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you sure you are not low on propane?
It appears there is very low pressure when the gas valve opens.
Check for a blockage in the burner tube. But it sure looks like a low pressure problem to me.
How do the cook top burners look?
Do you have 2 propane tanks?
Have you tried switching to the opposite tank?
Might be a bad regulator. Or auto switchover valve at the regulator.
Old 08-22-2016, 02:25 PM   #3
2013 16' Sport
Boulder , Colorado
Propane full both tanks, cooktop and fridge running normally.
Old 08-22-2016, 02:40 PM   #4
Long Island , New York
You probably have a spider nest inside the burner tube, which you may have to remove to clean properly with a bottle brush etc.:
http://www.airforums.com/forums/f516...ne-153298.html
Search for spider nest:
https://cse.google.com/cse?cx=011403...est&gsc.page=1
We had to do this a few months ago. You will have to remove 1-2 screws, and may be able to just loosen the others, to permit the tube to rotate so you can get inside. On ours the back screw was a pain to get back in, so if you just loosen it that will help. Each installation is different.
Good luck!
Peter
OTRA15 is online now   Reply With Quote
Old 08-22-2016, 04:04 PM   #5
2013 16' Sport
Boulder , Colorado
Tube cleaned! Heater working! Thanks everyone!
CQ
Old 08-22-2016, 04:34 PM   #6
Excellent thanks for the followup!
Old 08-23-2016, 12:54 PM   #7
1977 31' Sovereign
Lynnwood , Washington
Have you tried adjusting the flue??
Tom
TomKirk is offline   Reply With Quote
Diagnostic for CCC, AC and Furnaces cwf Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-23-2015 09:48 PM
diagnostic help needed: battery/converter Seecue Electrical - Systems, Generators, Batteries & Solar 4 07-31-2013 02:06 PM
Backfire - Diagnostic Port PeterK Mechanics Corner - Engines, Transmission & More... 6 02-07-2013 08:27 PM
LEDs: tricking TV's diagnostic system patis Lights - Interior & Exterior 3 04-23-2010 11:52 PM
