Join Airstream Forums Today
Old 11-20-2011, 07:16 AM   #1
58 Traveler
Rmiller51's Avatar
1958 18' "Footer"
Seattle , Washington
Need help w/propane plumbing
I am re-plumbing the propane lines in an old 19ft Traveler and need help with details. My plan is to a run 1/2” copper rigid main line down the center and “T” with soft 3/8” copper to each side. I will also cover the lines with some kind of flexible plastic tube or PVC pipe for protection. Does it matter what kind of copper pipe I use if it is covered? Type M, L, K?? What about single vs double flare?
The original trailer had all kinds of connections and shut offs inside the trailer which could be many potential sources for leaks. The main outside “T” to each side will supply two appliances on each side. The old system ran a soft line to each side with a “T” and shut off to each inside. Should the new ”T” be inside or outside? Should I plumb in shut off valves for each appliance? If used, should these valves be inside or outside?
Thanks, Randy
Rmiller51 is offline   Reply With Quote
Old 11-20-2011, 09:27 AM   #2
1971 18' Caravel
1974 Argosy 20
1975 Argosy 22 Rear Door
Kooskia , Idaho
Type K soft copper for all the lines. Single flare will be fine. All valves and connections outside, under the rig. As few as possible connections inside the rig. Valves for each appliance are very nice.
idroba is online now   Reply With Quote
Old 11-20-2011, 11:34 AM   #3
58 Traveler
Rmiller51's Avatar
1958 18' "Footer"
Great! Thks, That confirms my research. Randy
Old 11-20-2011, 11:37 AM   #4
moderator
Airslide's Avatar
2001 30' Classic S/O
Novato , California
Images: 47
Send a message via Yahoo to Airslide
Welcome to the airforums Rmiller51,
Sounds like a nice project your involved in there. We would love to see pictures of your idea once installed. My only thought would be the placement of those copper pipes in the pvc piping. I believe they are exposed for inspection purposes. If the connections were to ever leak you may not know and those pvc pipes could be filled with gas.
Cheers Vinnie
Air-safe / Reese dual cam
2011 Dodge 3500 Diesel
6 speed manual 4x4
Airslide is offline   Reply With Quote
Old 11-20-2011, 12:09 PM   #5
58 Traveler
Rmiller51's Avatar
1958 18' "Footer"
Rather than a loose PVC pipe to cover the copper line, what do you think about using clear braided hose, slit along the length and zip tied for protection? This would be a tighter fit. Not sure if that would be the same kind of gas entrapment issue or not.
Old 11-20-2011, 01:09 PM   #6
lewster's Avatar
Marco Island, FL , Hood River, OR
Single flares may 'be fine' but they are NOT to current RVIA standards, which require DOUBLE FLARES at all flair fittings when used in LP applications. If you are going to do the job, DO IT RIGHT! A double flair takes a few seconds more to complete than a single one and has much better sealing properties.
Further, I would use rigid black pipe as the main line and branch from that with 'K-type' copper for the branch lines.
Lew Farber -RVIA Nationally Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.
AM SOLAR SALES & INSTALLATIONS .....MAGNUM INVERTERS.....LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS....BUT I'M STILL AROUND!
'61 Bambi plumbing ragin-cajun 1961 - 1963 Bambi 2 11-11-2011 01:23 PM
Sealing up plumbing openings KYAirstream Plumbing - Systems & Fixtures 3 09-05-2011 09:41 PM
'67 Safari plumbing diagram 2001sport 1966 - 1968 Safari 1 07-24-2011 09:08 AM
copper plumbing in 1965 Trade wind Dr Dan Fresh Water Systems 5 07-14-2011 07:41 PM
Interior Plumbing Vent and cap the outside? robwok Roof 5 02-14-2011 12:27 PM
