Old 02-01-2007, 11:53 AM   #15
LPG rods
Most Airstream LPG hold down rods from the mid 60's are pinned, not welded.
Old 02-01-2007, 12:36 PM   #16
Excella3287's Avatar
Hey Coastal Friend
Is yours welded or pinned?, perhaps the PO welded it. If I were closer I'd do it for Free well maybe a beer. Keep us posted as to what you do.
Excella3287 is offline   Reply With Quote
Old 02-01-2007, 01:29 PM   #17
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
Well, I think it is pinned, but the pin is not visible sticking in or out of the rod or "sleeve" it's in. If I look down the "sleeve" I can see a pin-like thing and the rod moves side to side, so I believe it's pinned.. but isn't the pin welded front to back inside the "sleeve"? I suppose I could just drill it out? And what type of pin is used?
sequoiacoast is offline   Reply With Quote
Old 02-01-2007, 04:00 PM   #18
They are called "split pins."
Old 02-01-2007, 04:50 PM   #19
Images: 59
I'm glad I read the "..Disaster Averted" thread. Thanks.
Why on earth would anyone drill a hole in the Hold Down rod and use a pin after reading that!
Mine is welded, thank goodness.
Old 02-01-2007, 05:29 PM   #20
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When I went to new tanks on my TW, I removed the pin out of the rod and found another hole in the rod futher down. Put a new pin in the new location and it just the right spot. Getting the pin out took a bit of work.
Richard
Old 02-01-2007, 05:55 PM   #21
1968 24' Tradewind
Eureka , California
"Lots of work..." Boy, you're telling me! So far I have broken one bit and am drilling away- at a funky angle with only interruptions and no results (ugh kids!).
I googled split pins- I know them as cotter pins- and I have to agree with markdoane, they don't seem up to the job. Maybe they make thicker heavy- duty types?
Old 02-01-2007, 06:18 PM   #22
Split pins are punched out, not drilled out, since they are made from spring steel, which is very hard.
The split pin installation has been used by many RV manufacturers for some 40 plus years.
Old 02-01-2007, 06:21 PM   #23
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
argh...
I so remember this. I hammered the rod down... and the pin broke fairly easily (after I too kept drilling away). A punch works too, I believe. I replaced the rod with treaded rod that fits (just take your holder to the hardware store to find another). I then bolted the rod with double bolts and lockwashers above and below the "sleeve." Much safer than the ol rusty pin.
Good luck! Gonna polish those tanks?
Marc
Old 02-01-2007, 06:22 PM   #24
1968 24' Tradewind
Eureka , California
Well punching sounds good at the moment... I have tried that too- I think my awl is too big- must search for something skinnier....
Yeah I'm gunna polish... I have to do that before filling, right!?!
Old 02-01-2007, 06:32 PM   #25
Marc
The typical LPG rod is harder than the mild steel treaded rods.
Old 02-01-2007, 10:07 PM   #26
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Me too...
Mine is welded to the sleeeve as well. I just assumed that yours was too Tanya! I would weld it after finding out about the possibility of the rod breaking at the pin hole. Maybe that's why it moves back and forth in the sleeve so much. perhaps it is getting ready to break. I hope not. I agree with Andy that the original rod should be better made than the newer threaded one. I hope everything works out for you. Let us hear how you make out on this. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-02-2007, 12:23 PM   #27
1968 24' Tradewind
Eureka , California
I got the **%$ split pin out- and it looks nothing like a cotter pin, which is what came up when I googled it.
How'd I get it out? First, tried to drill it- broke the bit off. Second, took the awl to it, but it is so close to the front of the trailer that it wasn't working. Tried to hammer down to see if it would even move-NOPE. Third, took the skinniest chisel I have and stuck it down, next to the rod to cut through the pin. That worked, but the chisel got stuck. 4th, got the WD-40, a bunch of pliers..... in the end I got it out... and that split pin is strong!! On its way out it got stuck again (rod was free) and I couldn't even dent it with a chisel and hammer. So, here's some pics, I'm off to the hardware store to see about a new metal drill bit, and check out the "split pins".... wish me luck!
I'm going to have new safety chains welded on and will ask him to add a spot to the rod also.
Name:	rod is coming out.jpg
ID:	31735   Click image for larger version
Old 02-02-2007, 01:19 PM   #28
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
It probably won't help now....but we call those roll pins A split pin is more like a cotter pin.
Aaron
WBCCI #XXXX AIR #2495
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
