Old 09-05-2012, 05:38 PM   #1
mogadore , Ohio
Need help installing a 4" gas vent
Anyone know where I can get either a 90 4" vent so i can go out the side or a 4" vent that I can go through the roof of my airstream.
I am installing a wall hung tankless water heater in a closet and I dont know where to start with the vent.
Name:	water htr 2.jpg
ID:	167535   Click image for larger version
Marchok is offline   Reply With Quote
Old 09-05-2012, 05:58 PM   #2
cameront120's Avatar
1972 25' Tradewind
North Vancouver , British Columbia
Any supplier of plumbing/mechanical supplies will have them. I suspect you'll need a B-vent (they usually have a 4" inside diameter and 6 or 7" outside diameter.
North Vancouver, BC
cameront120 is offline   Reply With Quote
Old 09-06-2012, 05:09 AM   #3
mogadore , Ohio
Thanks. I'm stuck on how thick the wall/ceiling is and whether to use a vent similar to the fridge vent or more like the vent used on the furnace
Old 09-06-2012, 06:52 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Most AS walls are 1 1/2 inches thick. At least my 1968 is. Fridge vent might be a little over kill. Look at some of the vents on vintage trailer supplies web sight and see if the will work.
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline   Reply With Quote
Old 09-06-2012, 09:02 AM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
gas fired wall hung instant water heaters generally use a coaxial vent arrangement that often projects more than a few inches from their mounting wall.
check with your heater manufacturer for their specification.
if the water heater is built & certified for RV use, the manufacturer will have the right parts available through their normal distribution channels.
if it's not built & certified for RV use, you might want to rethink what you're using.
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
jm2 is offline   Reply With Quote
