Old 09-05-2012, 05:38 PM   #1
mogadore , Ohio
Need help installing a 4" gas vent
Anyone know where I can get either a 90 4" vent so i can go out the side or a 4" vent that I can go through the roof of my airstream.
I am installing a wall hung tankless water heater in a closet and I dont know where to start with the vent.
Name:	water htr 2.jpg
ID:	167535   Click image for larger version
Marchok is offline   Reply With Quote
Old 09-05-2012, 05:58 PM   #2
cameront120's Avatar
1972 25' Tradewind
Any supplier of plumbing/mechanical supplies will have them. I suspect you'll need a B-vent (they usually have a 4" inside diameter and 6 or 7" outside diameter.
North Vancouver, BC
Old 09-06-2012, 05:09 AM   #3
mogadore , Ohio
Thanks. I'm stuck on how thick the wall/ceiling is and whether to use a vent similar to the fridge vent or more like the vent used on the furnace
Old 09-06-2012, 06:52 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Most AS walls are 1 1/2 inches thick. At least my 1968 is. Fridge vent might be a little over kill. Look at some of the vents on vintage trailer supplies web sight and see if the will work.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-06-2012, 09:02 AM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
gas fired wall hung instant water heaters generally use a coaxial vent arrangement that often projects more than a few inches from their mounting wall.
check with your heater manufacturer for their specification.
if the water heater is built & certified for RV use, the manufacturer will have the right parts available through their normal distribution channels.
if it's not built & certified for RV use, you might want to rethink what you're using.
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
