Old 09-01-2015, 12:06 PM   #1
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
Need help for parts to replace oven pilot light propane feeds
I have checked here in the local area for propane line and fittings for our Magic Chef oven pilot light in our '98 Excella. The propane line broke where it exits the oven at the back. The line is 4 ft long by 3/8 " wide and the fittings at each end with need the compression pieces. Photo attached of the compression fittings. Top fitting is for the oven control end and the bottom is for the pilot light.
Any help or suggestions would be greatly appreciated. Hate to think I have to buy a new stove for a few dollars worth of parts.
Name:	pilot light fittings.jpg
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 09-01-2015, 12:28 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That is going to have to be made up. If you are unable to do it yourself contact a local gas company. Mine is Blossum and that can made up any type or shape gas line. It helps if they have the old one in hand to work from.
MICHAEL
Old 05-26-2016, 06:10 AM   #3
Gilmurr's Avatar
Found the parts needed on ebay....Robertshaw pilot tubing part number 11-292. 1/16 in aluminum tubing with fittings. replaced in 15 minutes....good as new.
David & Andrea
RSS feeds not working? barrettjl Forum Admin, News and Member Account Info 1 12-03-2012 02:25 PM
looking for help with Magic chef oven pilot light jayg Stoves, Ovens & Microwaves 2 06-01-2011 04:18 PM
Propane weenie here... how do you light the oven pilot? Stella Stoves, Ovens & Microwaves 6 06-14-2010 11:10 AM
RSS Feeds suggestion for AirstreamClassifieds.com Westfalia Forum Admin, News and Member Account Info 2 02-10-2008 09:11 AM
Maytag Oven Pilot Tube Parts Needed. jlovelady Stoves, Ovens & Microwaves 1 07-30-2006 06:06 AM
