Old 04-12-2006, 08:04 PM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Unhappy need a problem fixed on my tanks
I went to refill my tanks they come from the factor on my air stream .but they said they cant fill them anymore until i replace the on&off nods is there anyone around clarksville area or close to.That will replace these for me ?
Angel73 is offline   Reply With Quote
Old 04-12-2006, 08:34 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I am guessing that you're talking about the fill valves for your propane tanks?
There is indeeda new style safety valve available, called an OPD valve.OPD stands for Overfill Protection Device.
Anyways, look in teh yellow pages for your area, and call propane suppliers. There should be an industrial propane place in every county. They can usually do this for you. If not, you will have to buy new tanks.
If your tanks are lauminum tanks, then they are well worth converting.
Uwe
www.area63productions.com
Old 04-12-2006, 10:11 PM   #3
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I got mine from ebay ,put them on myself, good to go !!!
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 04-14-2006, 08:07 AM   #4
Angel73's Avatar
1975 31' Sovereign
Images: 65
yes they are the aluminum tanks that came with the trailer. but noone around here does think so far(change them out i mean)
Old 04-14-2006, 08:10 AM   #5
Angel73's Avatar
1975 31' Sovereign
Images: 65
How did you get the old one off?Iam scared of messing up the brass fitting inside well it looks to be brass.How did you get the beed around the old one to let go.
Old 04-14-2006, 08:39 AM   #6
Images: 59
Angel,
Take your time and find a propane shop that knows how to do it. Aluminum tanks take a different dip tube than the steel ones.
markdoane is online now   Reply With Quote
Old 04-14-2006, 11:08 AM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Angel73!
When I had the aluminum tanks on my Minuet updated and re-certified, I ran into similar difficulties. You might be able to try what worked for me -- my coach was at my regular Airstream dealer for maintenance and I mentioned the problem to the Service Manager -- he had the contact information for a company that was fimiliar with refitting the aluminum tanks. The procedure was handled quickly, efficiently, and at a very reasonable cost -- about $30 per tank (20 pound). Since my coach had to remain with the dealer for some repairs, the Service Department even expedited the tank update for me.
Good luck in locating a shop to update your tanks -- they are out there, but not always easy to locate!
Kevin
Kevin D. Allen
AIR #827
Old 04-14-2006, 07:15 PM   #8
1976 25' Caravanner
Campton , New Hampshire
Try one of you local Propane suppliers , they may be able to order them for you , they are Worthington alum tanks . If you Google - Worthington you can find your closest distributor , S. C. and GA , and have them shipped to you . Then find a local propane service to have them installed and re-certified. They have to be re-certified every 5 years.Good luck
ticki2 is offline   Reply With Quote
Old 04-15-2006, 10:15 PM   #9
Angel73's Avatar
1975 31' Sovereign
Images: 65
thanks
After many weeks of looking.I found someone well the only one in the next 5 towns...lol They said they could do it for 30 for a 30gal and 40 for a 45 gal..And guess what mine a 35 gal tall. Two of them wont this be fun.Ill make sure the long tube will be what they put in ty
Problem fixed lbrodsky 2001 Safari 1 12-16-2002 08:42 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
