Originally Posted by MMilhoan
Help, I am trying to hook up my water and run my grey water out with a hose to trees in my back yard. I'm not using the black tank at all. I have replaced the toilet with a composting toilet.
The manual has no diagram of where the fresh water goes in. Is there a place to hook up the hose on both sides of the excella or only on the door side? Do I still use the fresh water tank if I am hooked up to a hose from a well?
I am new at this and need some savy advice.
Thanks!
Melodie
Congrats on the 34....we have the same trailer.
The city/well water hose hooks up to the street side (drivers side) at the rear corner of the trailer. The fresh water fill is via the small keyed door on the other side approximately over the center wheel. There is no screw on connection for adding the fresh water, just stick the hose in and add the water slowly. It will hold app 50 gallons.
If you are hooked up to city/well water with a hose, you do not need to use the fresh water in the tank....it must be pumped using the on board water pump.
Glad to have you in Club 34.
John
