Old 06-11-2015, 06:45 PM   #1
1993 34' Excella
Abiquiu , New Mexico
Naive new owner of 93 Excella 1000
Help, I am trying to hook up my water and run my grey water out with a hose to trees in my back yard. I'm not using the black tank at all. I have replaced the toilet with a composting toilet.
The manual has no diagram of where the fresh water goes in. Is there a place to hook up the hose on both sides of the excella or only on the door side? Do I still use the fresh water tank if I am hooked up to a hose from a well?
I am new at this and need some savy advice.
Thanks!
Melodie
MMilhoan is offline   Reply With Quote
Old 06-11-2015, 07:25 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm not totally sure for your model. On mine, all the "business" connections are "street side" - the opposite of the door (which is curb side).
You should see a connection the size of a garden hose connection that says something like CITY WATER. You would connect your water source here to get water flowing throughout your trailer. That same side of the trailer (underneath) would have the connection for what's affectionately known as the "stinky slinky" - the wider (3") hose that drains your tanks (or in your case, the gray tank).
Good luck!
Old 06-11-2015, 07:37 PM   #3
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Just make sure u use new clean white hose for city water and do not confuse city water with fresh water, i have both on mine and fresh water is where i hook up green hose to clean out black tank. Do not know if you have borh, but just in case.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 06-11-2015, 08:06 PM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Thanks!
Melodie
Congrats on the 34....we have the same trailer.
The city/well water hose hooks up to the street side (drivers side) at the rear corner of the trailer. The fresh water fill is via the small keyed door on the other side approximately over the center wheel. There is no screw on connection for adding the fresh water, just stick the hose in and add the water slowly. It will hold app 50 gallons.
If you are hooked up to city/well water with a hose, you do not need to use the fresh water in the tank....it must be pumped using the on board water pump.
Glad to have you in Club 34.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-11-2015, 08:58 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Welcome fellow 34'er!
As above... All "connections" on street(port/left side).
For drain of gray you can get a cap with a garden hose connection. Then run hose where you will. (Obeying the law of Man and physics of course)
Peace and Blessings..
Channing
WBCCI# 30676
Perhaps a naive awning question beatrix1 Awnings 1 05-05-2015 04:03 PM
Am I just a naive semi-newbie, need elder advice. cdfriend Towing, Tow Vehicles & Hitches 9 12-28-2014 08:03 PM
Numbers? I am so naive !!!! Alderman Airstream History 14 04-26-2011 04:51 AM
Dangerously Naive '78 Tradewind Owner hessehesse Member Introductions 6 07-19-2009 02:03 AM
