Old 06-17-2008, 10:55 AM   #1
Palo Alto , California
Mystery of the beeping trailer
Last night was rough. My disclaimer is that I am braindead between 1:00am and 6:00am. Basically, my trailer started beeping periodically last night, waking me up. I couldn't figure out what was beeping, and the fact that it would beep maybe once overy 20 minutes was incredibly annoying because it was just enough time to drift off to sleep and too much time to locate the source of the noise. Over 4 hours I grew increasingly frustrated, each time trying something new - taking down the smoke detector, then the C02 detector, then flipping circuit breakers, then unplugging the external power, then turning off the gas, and finally (idiotically) using scissors to cut the connecting wires to the LP Gas detector. It turned out that the beeping was coming from the smoke detector, and that taking it down wasn't enough to disarm it - I needed to remove the dying battery.
Anway - I've tried reattaching the wires to the LP detector, but I can't get the thing to turn back on. I might need to buy a new one. Does anyone have suggestions on good LP detectors to get? Since I'm mechanically inept, I'd prefer to get something that is really easy to install - has anyone used one that runs off a disposable battery rather than being wired to the trailer battery?
By the way, I've been living in a 19' Safari for a year now and love it, although I'm completely new to RVs and really don't know what I'm doing. I haven't done any traveling, but will get a big enough truck to do so one day
Thanks a bunch.
qgmmon
gqmmom is offline   Reply With Quote
Old 06-17-2008, 11:02 AM   #2
cameront120's Avatar
1972 25' Tradewind
If you go to Home Depot, you can get a propane detector that will plug directly into the wall socket. If you have a socket down near the floor this is ideal. Mine has a built in extension which allows me to use a socket that is high on the wall but mount the detector a few inches above the floor.
Kidde - Plug-In Carbon Monoxide Propane Natural Gas Alarm with Battery Back-up - 900-0113-05 - Home Depot Canada
North Vancouver, BC
Old 06-17-2008, 12:01 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Isn't that a crazy-maker? We had one stuffed away in a closet and it started chirping like a cricket-drove us nuts and we've never recovered.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-17-2008, 12:16 PM   #4
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Been there with the beeping. The LP detector on my 04' Bambi liked to beep when the battery voltage got low and the heater was running.
If you cut the wires with it using scissors, there is a good chance that you shorted the circuit and popped the fuse. The fuse is located under the road side dinette seat in the forward access compartment, around the area of the pump. It is a glass inline fuse in a clear or white plastic case.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 06-17-2008, 12:23 PM   #5
redstart's Avatar
1998 34' Limited
ont , Ontario
Recently had a new LP detector installed here in Canada and it was only $150 including labour - just something to think about before you go spend 60$ on a plug in one.
redstart is offline   Reply With Quote
Old 06-17-2008, 02:33 PM   #6
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
In my previous RV, I found it interesting that the LP detector did not know the difference between propane and methane. My dog like to fall asleep in front of it, and depending on her diet (sometimes she was quite gaseous) would cause the detector to go off in the middle of the night. It took us a couple of times before we determined the cause!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 06-17-2008, 02:47 PM   #7
redstart's Avatar
1998 34' Limited
ont , Ontario
Ok that is pretty funny! i am surprised my LP detector is not going off constantly (tooty dog, baby and husband). Who farted?
Old 06-17-2008, 08:53 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
On the other side of air freshness...the propellant in aerosol air fresheners will also set the things off. Ours is extremely sensitive.
We had a bad propane gas detector in our Bambi, too, at one point...it went off so often when the furnace kicked in, that our dogs finally began to associate the clicking of the furnace igniter with the gas alarm going off. So we had very unhappy, unnerved, shaking dogs for a long time... When they heard the igniter clicking, they'd start shaking in anticipation of the alarm going off. Finally, after many trips with few alarms, they are back to a point where the furnace can go on and they don't flinch.
TB & Greg and Abbey Schnauzer
#3954
Old 06-17-2008, 09:14 PM   #9
Ottawa , ON
How did you solve this? Put a small fan by the dog?
Old 06-17-2008, 09:35 PM   #10
TinShack's Avatar
2005 28' Safari S/O
Actually, she would have needed a LARGE fan! She liked to lay there because there was a rug there. We bought her a much more comfortable dog bed and put it in a different location. She was happy to move to the dog bed and we no longer had the problem.
Steve
Old 06-19-2008, 11:38 AM   #11
Wow! I'm thrilled to get such good responses on my first ever post. The story of CA Streamer's gaseous dog cracked me up.
I think I'm going to go with the Home Depot Kidde alarm for now, so I'll let you know if I have issues with it.
Old 06-19-2008, 11:50 AM   #12
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
BTW - Welcome to the forum!
Good responses are the norm, sometimes they're even informative.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-19-2008, 03:15 PM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Dave
Yeah Dave...but ain't funny fun.
We got a great crew here for sure
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 07-05-2018, 12:05 PM   #14
1988 34' Excella
Somerset , New Jersey
Mysterious beeping....
I have to chime in here. I looked up mysterious beeping in Airstream and found this thread. We are on our first trip in our 1988 34' Excella (affectionately known as Bella) from NJ to OR and back, in three weeks. Today is day 3 and we were pulled over at a Walmart in 'somewhere'Nebraska to buy something to rid ourselves of the smell that only a full black can provide. I gave a few spritzes of Febreeze to the offending bathroom, sprinkled some baking-soda based deodorizer on the floor and went out for a few minutes. As I stepped back in a regular, fairly loud, and annoying beeping began. We scrambled around trying to figure out where the beeping was coming from. Smoke alarm-nope. Gas detector- no gas on anywhere. We walked around scratching our heads wondering what to do and what impending disaster might be coming. Then, as mysteriously as it started, it stopped again. We locked Bella and hit the road, where I began my google search. It seems that indeed, the detector doesn't distinguish between propane and methane...and the air fresheners to get rid of the odors.
On the road, awaiting our next surprise. 😊
ExcellaBella is offline   Reply With Quote
need help on mystery wires twiggy137 Electrical - Systems, Generators, Batteries & Solar 4 05-27-2008 11:45 AM
What is it - mystery trailer azflycaster Off Topic Forum 13 01-25-2008 03:01 PM
Mystery Wires aeriqua Electrical - Systems, Generators, Batteries & Solar 2 10-03-2007 05:28 AM
Mystery MH PeterH-Airstreamer Airstream Motorhome Forums 4 01-01-2005 06:57 PM
Mystery trailer - info please Janet H Vintage Kin 13 08-19-2004 09:15 AM
