Old 06-02-2011, 12:30 PM   #1
Airstreamer
J5MM's Avatar
2012 27' FB International
Bellevue , Washington
Images: 78
My Gas Detector is not working, at all
Gosh that picture came out HUGE. Sorry about that.
I unscrewed my LP gas detector in hopes that someone on the forums could help me. There is absolutely no power coming into this unit. I have no green, orange or red lights. I have even pushed the "reset" button and nothing.
Even when plugged into shore power it does not work. Is there a fuse within this casing that needs to be replaced? I'm at a total loss....
{blog}Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
J5MM is offline   Reply With Quote
Old 06-02-2011, 01:00 PM   #2
Gainesville , Florida
There might be a fuse inline. These units are sometimes hotwired directly to the battery, check for a loose wire, . Sometimes these just need to be replaced,. jim
Old 06-02-2011, 01:10 PM   #3
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Mine did the same thing; I just replaced it with a unit from Safe Home Products, and that did the trick. It now works.
Steamy1 is offline   Reply With Quote
Old 06-02-2011, 03:11 PM   #4
Airstreamer
J5MM's Avatar
Images: 78
Did you have the same model of the one I have above? If so, can you send me a link to the one you purchased??
Old 06-02-2011, 04:28 PM   #5
Here is what I purchased through Amazon:
MTI 30-441-WT 12V White Surface Mount LP Gas Detector"
$49.95
In Stock
Sold by: Safe Home Products, Inc.
The difference between yours and mine, is that your is flush mounted. The manufacture is MTI, and they make several flush mounted units. Do a search on Amazon "LP gas detectors" and you will see all of them.
Good luck
Old 07-06-2011, 03:58 PM   #6
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Do LP Detectors Get Too Old?
Our LP detector (just like the one pictured above) has the light glowing yellow (orange?) and when we press the 'test' botton nothing happens. We do not smell any propane gas, but we do want the unit to function properly. Do they 'age out' like CO2 detectors do and need to be replaced every few years?
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-06-2011, 04:59 PM   #7
Apparently they do, which is what happened to mine.
Old 07-22-2011, 08:05 AM   #8
Scott J-24's Avatar
We received a new Atwood Series 2001 the other day. It cost <$35.00 including shipping from our local AS dealer. I am going to install it today but wanted to ask a question before I start. My detector appears to be directly wired to the battery. I presume that I just disconnect the battery by pulling the cables off the battery posts. Is there a special order of removal (eg., red/hot wire first? Any other issues I should be aware of? I don't want to fry my 12v system, so I thought it best to ask before I start.
WBCCI #1215
Air #54601
Old 07-22-2011, 08:08 AM   #9
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Always remove the negative first and install the positive first. This removes the chance of shorting out your wrench if it comes in contact with the trailer.
Richard
Old 07-22-2011, 08:21 AM   #10
Scott J-24's Avatar
Thanks, glad I asked! BTW, I have two 6 volt batteries wired in series. Does this make any difference on how I approach this?
WBCCI #1215
Air #54601
Old 07-22-2011, 08:47 AM   #11
George
2007 25' Classic
Calgary , Alberta
Disconnect LP gas detector
I presume that I just disconnect the battery by pulling the cables off the battery posts.... Any other issues I should be aware of? I don't want to fry my 12v system, so I thought it best to ask before I start.
The LP detector wiring should have an inline fuse. In my trailer (2007 Classic), the detector is wired to the positive bus bar underneath the gaucho in the front. The inline fuse (white holder) is within half a foot of the bus bar.
If you find it, just open it, don't bother with the battery.
Also, I wouldn't replace an LP detector until I've made sure the old one actually gets power. (The first post in this thread says the unit gets no power).
George
2007 Classic 25'/ 2013 Cayenne GTS/ 2015 GMC 2500HD Denali
gwmc is offline   Reply With Quote
Old 07-22-2011, 08:55 AM   #12
Scott J-24's Avatar
Yes, we have power getting to our LP detector (light is steady orange). The OP was J5MM and I am piggybacking on his thread because he had the same type of detector. Thanks for the tip on the in-line fuse.
WBCCI #1215
Air #54601
Old 07-22-2011, 09:13 AM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
The key is to remove the connection to the trailer from the negative side of the battery(s) before you start on the positive. If the negative is removed, the positive will not short to the trailer if it comes in contact.
When I was in the USAF I saw a few wrenches welded to the side of the plane when the crew chief did not follow the correct procedure.
Richard
Old 07-22-2011, 07:04 PM   #14
Scott J-24's Avatar
Thumbs up New LP Detector Installed!
Thanks for all of your help. Installation was a piece of cake! Couldn't locate the in-line fuse so I pulled the battery cables and cut out the old detector and crimped on the new one. Less than a 5 minute job. Great to see the little green light blinking and knowing we are safer than before.
WBCCI #1215
Air #54601
Frozen gas valve robert claus LP Gas, Piping, Tanks & Regulators 6 05-10-2011 07:18 AM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
How can I fill my US Ali gas bottles with LPG in the UK??? shinny67 LP Gas, Piping, Tanks & Regulators 7 01-14-2011 09:42 AM
