Old 01-16-2015, 09:50 PM   #1
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Mounting New LP Regulator Troubles
My old regulator on the 84 Excella looked like this:
When mounted it looked like this:
I purchased a new regulator from the propane dealer.
It looks like this:
The old regulator was on 2" center at the holes and 3" nipple to nipple.
The new regulator is 3.5" centered on the holes and 4.5" nipple to nipple.
The new regulator will not mount on the existing bracket and allow the tanks to be placed in their hoops. And of course the Aluminum tank cover won't go over the bottles because they can't sit in the hoops.
So, the conundrum is: How do I mount the regulator so the tanks sit in their hoops, and I can continue to use the Airstream Tank Cover?
The tank cover has the domed lid like this one.
I would be interested in solutions others have used to solve this problem.
Thanks!
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 01-17-2015, 03:56 PM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Old regulator:
Name:	ImageUploadedByAirstream Forums1421535291.053238.jpg
New regulator:
Name:	ImageUploadedByAirstream Forums1421535314.281132.jpg
Is there a source for a new regulator that is closer to the old one at 3" nipple to nipple instead of 4.5" nipple to nipple?
David
TAC # TX-18
AIR # 410
Old 01-17-2015, 05:15 PM   #3
Wayward's Avatar
Cary , North Carolina
Have you considered relocating the regulator? On my Safari, it is mounted up high on a metal bracket that is torqued down by the tank hold-down bracket.
You may need new hoses but that could be a good thing anyway.
(Sorry I do not have picture of the top-mount regulator on mine but it looks sorta like this....
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-17-2015, 05:47 PM   #4
2000 30' Excella
Toledo , Ohio
I did what Wayward said the bracket is available from Airstream and those 2 holes in the regulator in your second picture will mount to the new bracket raise it up high on the tanks and put it on the other side of the tanks with new hoses . mine is a 1985 and had the same setup as you .
woodfox45 is offline   Reply With Quote
Old 01-17-2015, 06:01 PM   #5
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Good to know! Thank you!
David
TAC # TX-18
AIR # 410
Old 01-19-2015, 12:48 PM   #6
1983 31' Excella
The Woodlands , Texas
I purchased from Holiday World RV an Excela - Flow Auto Change Over Regulator. Part # 06-0443 and it fit in the same spot on my 83 Excella. It's made in USA. I would suggest you change the hoses too. This Texas heat it tough. Gin
Air83 is offline   Reply With Quote
Old 01-25-2015, 04:36 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I ordered the new tank hold down bracket with the tongue bracket regulator mount.
However, the provided holes placed the regulator too high and would not allow the tank cover to be placed.
Therefore, I took an old license plate and made an adaptor bracket to mount to the tongue, then mounted the regulator to the adaptor bracket.
Next is new hoses as they will all require new lengths.
New setup has been tried and fits.
Here it is prior to the new hoses.
Name:	ImageUploadedByAirstream Forums1422228926.267728.jpg
ID:	231095Click image for larger version
Name:	ImageUploadedByAirstream Forums1422228939.252828.jpg
ID:	231096Click image for larger version
Name:	ImageUploadedByAirstream Forums1422228952.533685.jpg
ID:	231097Click image for larger version
Name:	ImageUploadedByAirstream Forums1422228965.421407.jpg
David
TAC # TX-18
AIR # 410
Propane Regulator mounting? mimiandrews LP Gas, Piping, Tanks & Regulators 18 03-07-2009 10:10 AM
Regulator Mounting? dnrtheil LP Gas, Piping, Tanks & Regulators 2 04-03-2008 11:27 AM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Water troubles... Sneakinup Fresh Water Systems 5 01-10-2004 09:54 PM
