Old 09-14-2004, 09:27 AM   #1
walter1's Avatar
1964 22' Safari
Foresthill , California
Metric LPG fittings, Therm'x heater
I need propane line info. I have a French made Therm’x catalytic wall heater from a 68 AS, I want to install it in my 64 Safari. The line from the heater unit has banjo fitting at heater and metric compression fitting at other end. I need to extend this line about 6 inches with 2 bends. Parts required...metric compression fitting union, tubing, 2 compression fitting nuts w/ferrules. Simple. Where can I find metric tubing and fitting suitable for LPG? It appears to be approximately 3/16 size line but we confirmed the fittings are actually 1.25 metric thread. I have the original piece that adapts this size to standard 3/8 flare tubing in AS but need to extend the small tubing, can’t just reposition adapter and lengthen 3/8 tubing. Any ideas or sources? Thanks, Walter
walter1 is offline   Reply With Quote
Therm'x catalytic heater Dwight Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-29-2012 08:28 PM
Therm'x safety heater trio Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-05-2010 03:09 PM
Therm'x Catalytic Heater Operation walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-07-2004 10:02 AM
Water Heater By-Pass? TroutStream Water Heaters, Filters & Pumps 4 09-01-2004 07:15 PM
