Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 03-21-2014, 05:26 PM   #1
2008 27' International CCD FB
Lakeway , Texas
Marshall pigtails with 3/8" male fitting
I have a 2008 International 27FB CCD, FB. Trying to replace 12 inch gas pigtails. The male connector is 3/8" , NOT 1/4" which seems to be the only one sold now. I have searched and searched everywhere and called several AS dealers to no avail. Is an adapter the way to solve this?
2goldens is offline   Reply With Quote
Old 03-22-2014, 12:57 AM   #2
2005 19' Safari
GLENDALE , AZ
Pipe fitting adapters
Without a photo, I am unsure which adapter you need. Here are links to several that might work:
Amazon.com: Anderson Metals Brass Tube Fitting, Coupling, 3/8" Flare x 1/4" Female Pipe: Industrial & Scientific
Amazon.com: Anderson Metals Brass Tube Fitting, Half-Union, 3/8" Flare x 1/4" Male Pipe: Industrial & Scientific
Amazon.com: Parker 6-4 RB-B Brass Pipe Fitting, Reducing Hex Head Bushing, 3/8" NPT Male X 1/4" NPT Female: Industrial & Scientific
Amazon.com: 3/8" NPT Male to 1/4" NPT Male Brass Pipe Hex Reducer/Reducing Nipple Fitting/Adapter: Industrial & Scientific
If none of these are the right one, there are links on these Web pages to other adapters.
Note: All of these are standard fittings available from Home Depot, Lowes, Ace Hardware, etc.
Old 03-22-2014, 07:37 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sounds like you need a 3/8 to 1/4 bushing if the new pigtail is 1/4 and you current female connection is 3/8. That is a very common fitting that any Big Box should have
2004 Excursion 4x4
Old 03-22-2014, 08:35 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Replace the regulator with a new one with 1/4" inverted flare inlets.
Two-Tank Regulator
Gas pigtails are inverted flare and cannot be adapted to NPT with bushings.
Old 04-03-2014, 09:46 PM   #5
S.S. Tramp
1978 25' Tradewind
Yosemite National Park , California
2Goldens,
Did you find success? If so, how? I have a FEW days before I depart for the high country and I MUST find this solution, and I'm in the middle of nowhere! Just spent another $40 per week for internet to resolve this. I'm in a '78 international TW. HELP! My "fix it" guys here are all under the influence of beauty and "I'll be there tomorrow" is usually followed by "I went climbing/hiking... sorry". Connector or new regulator? (I thought my regulator was new??). Thanks for any info!!
Sassy
ibvegan is offline   Reply With Quote
Water heater tank hole repair at fitting: weld? rippie Water Heaters, Filters & Pumps 5 01-29-2014 04:02 PM
Pex fitting leak - toilet supply line eberrobw Sinks, Showers & Toilets 9 04-13-2012 09:55 AM
Brass fitting into water heater Bethany533 Water Heaters, Filters & Pumps 4 09-17-2011 08:37 AM
Dry fitting shell..shims needed? Becky B. Belly Pans & Banana Wraps 2 05-17-2011 05:44 AM
Axle Fitting in Reno (NV)??? Yomster Axles 7 03-29-2011 03:03 PM
