Old 01-03-2015, 03:09 PM   #1
1978 31' Sovereign
Euless , Texas
Main Gas Line Crimped
I have recently acquired a 1978 Sovereign International 31'. Upon inspection found main gas line crimped approx 5' downstream of connection to propane bottles. I cut the line behind the crimped area and disconnected from Propane regulator (see pics). I purchased some 5/8" type K copper gas line (same as original equip and some compression fittings. The plumbing supply store I advised that it would take special equipment not available at HD or Loews to bend type K tubing and flare this stiff tick walled tubing. I have been reading the Forum and found that compression fittings are not recommended, only flared fittings. so my dilemma is how to flare and bend type K tubing and how to join with flare fitting to the existing pipe. In the forum I have seen re-piping with black pipe and the softer L type 1/2" copper and where to purchase tubing bender and flaring tool at Harbor Freight for around $40. Harbor Freight does not have anything that will bend or flare 5/8" type K copper tubing. Has anyone out there in Forum land repaired copper gas tubing with the original 5/8" copper tubing. And where can I get tubing hangers? I went to boltproducts.com and found them, but they do not sell direct to public.
rbcarbo is offline   Reply With Quote
Old 01-03-2015, 03:15 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Got my soft tubing at Home Depot and the tubing bender there also or at ace hardware..
Old 01-03-2015, 03:25 PM   #3
1978 31' Sovereign
Euless , Texas
Thanks, but I would like to repair with the original type k tubing if possible.
Old 02-20-2015, 02:55 PM   #4
1971 27' Overlander
Jackson , Tennessee
To clarify some of the tubing questions, I would recommend Jammer's post #4 on this thread:
http://www.airforums.com/forums/f287...on-114851.html
I could not find soft K tubing or 5/8 - 3/8 reducing tees anywhere in my hometown nor at McMaster. I ended up ordering tubing from Copper Tubing Sales/ICS Industries which seemed the best place to get a shorter (still min 60') length. Other sources required 150' or more. No trouble bending this with spring-type tubing bender. I found the tees only through Amazon. (I wonder why VTS, OODM, etc, don't sell these.)
I hope this helps.
Alan
TennTex is offline   Reply With Quote
Old 02-20-2015, 04:22 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Looks like you've got all the good advice already. The insulated hangers you need can be found at Lowes in the electrical section. IMHO flared unions are the best way to go, and will be trouble free for the life of the tubing.
Welcome to the forum and if you need help PM me. We love our 78 Sovereign.
NavyCorpsman is offline   Reply With Quote
Old 02-20-2015, 05:14 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Take both pieces of tubing to a heating and air conditioning shop. They have the tools and know how to flare it. You could get the tubing there as well. If you don't have it yet.
Old 02-21-2015, 03:35 PM   #7
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I do a fair bit of work with LP and NAT gas and have a nice one piece tube flaring tool that works like a charm. It cost a bit more than the standard stuff you get at lowes, harbor freight etc but in the long run they preform better and the flares are correct size for the pipe and nut resulting in longer life with no leaks.
here the one I like.
WP160277 Flaring Tool - Grainger Industrial Supply
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is online now   Reply With Quote
electric hitch wiring crimped by Propane cover Anders79 Electrical - Systems, Generators, Batteries & Solar 8 12-11-2014 09:08 AM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Looking for main brake line connection James Schmidt Electrical - Systems, Generators, Batteries & Solar 9 06-27-2006 02:40 PM
main LP supply line from regulator Byron71 LP Gas, Piping, Tanks & Regulators 6 11-15-2005 12:08 PM
Pex-Crimped vs Qwest fittings StingrayL82 Plumbing - Systems & Fixtures 15 11-02-2005 12:04 AM
