Old 04-19-2014, 10:18 AM   #1
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
Magic Chef Oven won't stay lit...
I'm revisiting this issue... I had decided just to not use it but it has been bugging me so I wanted to search out a fix. I light the pilot, no problem. When I crank up the gas and temp the oven lights... When I turn it back down to let's say 400 degrees the gas in the pilot backs off and the end of the thermocouple (hope I have this part right) stops glowing red and the oven shuts off. If I leave it cranked up to 500 the thermocouple stays red hot and the oven remains lit...no problem... Problem is I can not bake or cook everything at 500 degrees! I have gas, the couple gets hot and keeps the oven lit until I turn it down a bit and the pilot flame retreats...not completely but just enough to let the sensor at the end cool off... Thoughts? Thanks....
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 04-19-2014, 10:24 AM   #2
richw46's Avatar
Lexington , Kentucky
The pilot light goes out too?
On gas ovens, if the oven temperature reaches the set temperature, the gas goes off but the pilot stays lit. Once the temperature drops below the set temperature the gas comes on again and the oven heats up until it cuts off again.
Is that what's happening?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-19-2014, 10:39 AM   #3
3campers's Avatar
1985 31' Limited
Images: 18
No the pilot light stays lit and the probe from the mercury control valve stops glowing red because the pilot flame shrinks... Usually the oven stays on for about a minute after choosing the desired temp then gas stops flowing to burner. I haven't waited long enough to see if the burner lights back up...but I can't imagine the oven reaching 400 degrees in just one minute... I will go try this and see if the oven relights...
1985 31' Limited
Old 04-19-2014, 10:48 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I will have to dig through my archives... it is one of two parts that is bad, one expensive, one cheap. From what I recall no way to test, replace the cheap part first if that doesn't work replace the expensive one... or buy a convection microwave.
Aaron
WBCCI #XXXX AIR #2495
Old 04-19-2014, 11:00 AM   #5
3campers's Avatar
1985 31' Limited
Images: 18
Aaron
Actually I pulled the convection and replaced with newer microwave..
***** I'll be damned... No one has explained it to me quit like you just have.. Like I said when the flame went out, I just assumed it was bad and shut it off to diagnose. I just went out to AS turned on oven to 400 in a minute it shut off ... sat and waited and sure enough it fired back back up on it's own!
I'm doing a major happy dance!! Thank you!!!
1985 31' Limited
Old 04-22-2014, 01:10 PM   #6
1989 34' Excella
Weatherford , Texas
Aaron, I have the earlier problem. The pilot in the oven will light and will stay lit. I turn the control value and the oven doesn't fire, at all. Pilot gets a little bigger but not much. Nothing happens. Which part is the cheaper one? I have a Magic Chef in a 1989 Excello.
2001 Ford Crewcab XLT 350 Powerstroke Diesel 4X4
Figures don't lie but liars can figure
Stogiemann is offline   Reply With Quote
Magic Chef won't stay lit !!!! purman Stoves, Ovens & Microwaves 6 08-07-2011 08:11 AM
Magic Chef, Robert Shaw oven won't work 63 Safari MT Stoves, Ovens & Microwaves 3 06-02-2009 03:41 PM
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 0 09-28-2007 07:45 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Magic Chef oven won't light, revisited Safari64 Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-23-2005 06:14 PM
