Old 07-30-2016, 12:54 PM   #1
Arizona Bound
2016 30' Classic
LAKE HAVASU CITY , Arizona
Question LPG valve
We just bought a 2016 classic and it has a LPG valve to hook up a gas grill and we hooked up the gas grill it's a small one and we could not get the grill to heat up we can see the gas going to it at a low flame but turned it way up and we could not get the grill to heat up on high any suggestions would be helpful thank you
Dberg8453 is offline   Reply With Quote
Old 07-30-2016, 12:58 PM   #2
"Cloudsplitter"
Question
How does it work on it's 1lb portable bottle?
Old 07-30-2016, 01:10 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
This has been covered a gazillion times on the forum. Most grills run on high pressure propane, a canister, and have a regulator. Your trailer port is low pressure, already regulated. You now have two regulators in series and pressure so low that you cannot grill. The possible solutions are covered in other threads.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-30-2016, 02:01 PM   #4
Arizona Bound
2016 30' Classic
The grill works fine with that 1 pound canister don't know if I need an extra adapter for the grill or a bigger grill
Old 07-30-2016, 10:49 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Larry hit the mark.
I do not know which "grill"'you have.. So hard to say what might be an option... But.. The AS has a regulator from your onboard LP tanks. The LP piping will then deliver the proper pressure and flow.. But you in this case you cannot have one regulator feed another one.
So, if you know how to do the plumbing, I would have a single attachment on the grill for LP from AS with another regulator for running off the 1LB bottle. You will end up with a regulator for the 1LB bottle... And the AS LP lines already have a regulator.
Confused yet??? If you burn down your AS, it was all on you... The Legal DPT had to step in here...
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-30-2016, 11:40 PM   #6
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Welcome to AirForums and Congratulations on your new 2016 Classic!
The suggestions above will help point the way to your solution.
I'm sure you will have many more inquiries as time goes by.
The Search engine is your friend and useful if used wisely: Go to the appropriate subforum (in this example: LP Gas), then click on "Search this Forum" (in blue tool bar), then click "Advanced Search", then enter the Key Word (let's say "grill"), and change the field from "Search Entire Posts" to "Search Titles only", which will provide more relevant threads (of posts). And on any thread, you can click "Search this Thread" for more specific results!
-- Bill
SilverGate is offline   Reply With Quote
Old 08-25-2016, 07:24 PM   #7
Boxite's Avatar
2008 22' Safari
A solution which works for most situations like this is to cut the hose at the portable regulator to remove it, and install a quick-connect-male fitting to connect to your Airstream low-pressure system.
This will likely work fine if your grill has individual burner knobs. If not, then you can regulate the flame with another valve installed inline.
Hope this helps.
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 07:18 PM
Fix or replace LPG regulator? Roundhead LP Gas, Piping, Tanks & Regulators 26 03-27-2004 03:28 AM
What you wanted to know about LPG and more femuse LP Gas, Piping, Tanks & Regulators 0 04-24-2003 10:12 AM
LPG or propane in the bottles ? brunoffrance LP Gas, Piping, Tanks & Regulators 3 12-17-2002 03:18 PM
