Old 10-18-2012, 02:10 PM   #1
wharf rat newbie
1978 31' Excella 500
keller , Washington
LPG Tank sensors
Hi Folks,
We have a 78 Excella 500 with a functioning Solid State Controller with an LPG tang level indicator for each tank. My manuals show B+ 12 v wiring to each tank so I'm assuming that there should be some type of variable resistor at the tanks, either weight or level, but the books do not show anything. What's missing. Prior to my purchase the tanks were reinspected and fitted with OPD valves.
Best Regards
pat hayes
wharfrat8995 is offline   Reply With Quote
Old 10-18-2012, 02:24 PM   #2
1977 Argosy 24
Milltown , Wisconsin
I think you may have lost your sensors when they changed the valves, unless they have a separate threaded bung with a sensor in it.
ventport is offline   Reply With Quote
Old 10-18-2012, 03:52 PM   #3
richinny's Avatar
2011 34' Classic
on my 94 the tanks had floats in them. i believe the rheostat is in the gauge in the top of the float where the wires connect.
Ricky
Old 10-18-2012, 05:58 PM   #4
1981 31' Excella II
New Market , Alabama
Yep if they put an OPD valve on it there is no sensor. I am facing that same problem. I have a nice float gage on my tanks and they will have to come off for the tanks to be filled.
You will have to buy new tanks with a double bung on them. One is for the valve and one is for the gage.
Perry
Old 10-21-2012, 10:58 AM   #5
wharf rat newbie
keller , Washington
So then are replacement tanks available which have the floats or are there floats available?
Old 10-21-2012, 11:32 AM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They are readily available, but there is a $60 (for 30# tanks) premium for the gauges over the base price. See 30 Lb. (7.1 Gallon) Vertical Aluminum LP Tank
Vaughan
