Join Airstream Forums Today
Old 01-31-2012, 06:50 AM   #15
moderator
Brandon , Mississippi
Originally Posted by 87MH View Post
I just ran into a problem I had not been aware of...
Found both of my aluminum 40's had bad internal sealing gaskets where the male fitting of the pigtail mates to the OPD valve.
These seals are not O rings, rather they are pressed into the valve during the manufacturing process....
Just wanted remind the Forum of a few more maintenance items for your periodic inspection list.
My OPD Valves have the same internal seal on a metal insert that is threaded into the valve...I know this because one backed out to the point the refill fitting wouldn't screw in.
Just one more thing to watch for...
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-31-2012, 08:30 AM   #16
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I saw the results of a 1 pound bottle exploding. I do not want to be in the same county if a larger tank goes up. You do not have to go overboard, but please take care of your tanks.
Sam
samb is offline   Reply With Quote
Old 01-31-2012, 09:02 AM   #17
eubank's Avatar
1967 30' Sovereign
Angel Fire , New Mexico
Yep, that little one-pound amount of liquid propane expands by up to 270 times when it becomes a gas.
Lynn
Sam
WBCCI 21043
Old 01-31-2012, 11:22 AM   #18
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
If I recall correctly, inspection in the US has to be at or before twelve years; ten in Canada. I don't know about re-inspections.
A US approved tank between 10 and 12 years may be a problem when and if you go to Canada.
Gene
CrawfordGene is offline   Reply With Quote
Old 01-31-2012, 01:21 PM   #19
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Send a message via ICQ to Skater Send a message via AIM to Skater Send a message via Yahoo to Skater
Sam
On the other hand, I've heard of tanks falling off campers and hitting the road with nothing more than damage to the paint. They're pretty strong.
1995 Airstream Classic 30' Excella 1000
B190 Owners: The site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
Skater is offline   Reply With Quote
Airstream of Mississippi Overlander & Sea Commercial Listings 23 05-03-2012 01:44 PM
