Old 05-24-2014, 05:10 PM   #15
1999 28' Excella
New Orleans , Louisiana
The generator is by the back bumper of our 28' and runs on gasoline. The detector is OLD..needs replacing. Going to turn the gennie on again this afternoon and look at light strength. When reset with test button it shuts up..we will see what happens. Thanks for the tips.
badkat is offline   Reply With Quote
Old 05-24-2014, 10:29 PM   #16
1999 28' Excella
OK, never went on with generator running..turned it off and later with nothing on went off a couple of times...guess it is dying. Kinda scary to sleep but guess it is a malfunction.
Old 05-25-2014, 09:23 AM   #17
Denis4x4's Avatar
Durango , Colorado
I will buy into the need for smoke detectors along with carbon monoxide detectors in RV's. However, after dealing with an LPG detector that when off three times in the wee hours of the morning the first night out, I disabled the damn thing. Having survived 40 years of RVing without one, I decided to take my chances!
Question: are these things mandated by the government?
Denis4x4 is offline   Reply With Quote
Old 11-22-2014, 01:09 PM   #18
StagrLee's Avatar
2012 25' FB Eddie Bauer
This is what came with with the Atwood Assembly No. 36720 RV Propane Gas Detector I ordered (and the older Atwood ProTechTor that came with my 2012 25'FB EB).
The bracket that came with the one I recieved isn't a perfect fit in the Airstream cutout for the larger, older ProTechTor; but works. Its close to the floor so you can't really tell that the bracket isn't flush with the paneling at the bottom.
Atwood lists the bracket separately as part number 35181 but nobody carries it and Atwood documentation doesn't mention that it is included with part 36720. I'm wondering if it's inclusion is temporary because lots of listings (Amazon and others) don't show the bracket adapter which you will need to retrofit from the older generation to the newer generation sized detector.
My ProTechTor only made it 3 years before it failed.
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
Old 12-05-2014, 11:20 PM   #19
StagrLee's Avatar
I wrote a detailed blog of updating the Atwood LP Detector from the old style to the newer, smaller part. I also took the time to move the detector to cutoff when the storage switch is thrown. Not a difficult mod...
No Excuse For Thinking: Airstream LP Detector Overhaul
see the above link for details
"Stagr" Lee
Old 11-22-2015, 02:53 PM   #20
Durango , Colorado
Does anyone know where the inline 1 amp fuse is for the LP detector that is hard wired to the batteries in a 2007 19ft. Bambi? I was replacing the old Atwood with a new Atwood LP detector and assume i blew the fuse because with just changing the units and not cross wiring I lost power to the new unit. Everything was working fine but wanted to replace due to safety recommendations. Old unit was 8 years old.
Ken
pkm123 is offline   Reply With Quote
Old 11-22-2015, 11:35 PM   #21
StagrLee's Avatar
Hit the storage switch by the door. Wherever you hear the clunking sound, that is where the battery cutoff solenoid is. Find the inline fuse wired prior to the solenoid is probably the one you are looking for. I would guess its under the bed.
"Stagr" Lee
Old 11-24-2015, 09:59 PM   #22
Durango , Colorado
Thanks Stagr, "great pseudonym by the way"
Lew helped me locate the 1 amp fuse holder in my Bambi under the dinette close to the buss bar. Different colored wire of course than what was at the detector. Thanks for your help. This fuse was mentioned in the owners manual but not its location. Your advice would have located it also however my solenoid is under the dinette.
Ken
Old 09-13-2016, 11:50 AM   #23
Fostoria , Ohio
Smoke/gas alarm goes off in 1990 Excella
My trailer is sitting idle after a short trip bringing it home yesterday. After sitting all night, the gas indicator and smoke alarm went off. The tanks are turned off and not been used. I did see the switch was "on" on the stove but I did not smell any gas. I don't know where to turn it off but I went back to the furnace thermostat and played with that out of desperation and it seemed to turn off the alarm. Up front at the bottom below the stove unit is a green light that comes on (with just trailer battery running) and says indicator or something like that. Do I press on anything to reset and or stop it? Also the small alarm on the ceiling went off too. They both have stopped now.
appygirl is offline   Reply With Quote
Old 03-03-2017, 05:15 PM   #24
Boxite's Avatar
2008 22' Sport
My Atwood "ProTECHtor" Series 2001 LP Gas Detector blinks it's green light just like it should.
It also "tests" ...just like it should.
But using my propane weed-burner and a 20 lb. tank I flooded it with propane and ..... nothing/nope/nada. POINT IS: PUSHING THE TEST BUTTON DOESN'T PROVE MUCH.
Searching Amazon does not show this model available... but Atwood's website describes it as if it's still in production.
Reading this thread pretty well convinces me to buy the more modern Atwood 36720 unit.
Anyone disagree?
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 03-24-2017, 11:17 PM   #25
Boxite's Avatar
2008 22' Sport
Since no one disagreed...(heh-heh) ... I ordered the Atwood unit and installed it.
Like others have said, the adaptor plate accompanying the newer unit is smaller than the OEM Series 2001. However it isn't a total loss, as if you throw the old unit away...BUT KEEP THE OLD ADAPTOR... the new adaptor will mount into the old one.
Drilling 4 holes mounts the new unit with the small adaptor plate onto/into the old plate and it ends up looking just fine.
Rambox
Old 11-16-2017, 02:32 PM   #26
La Pine , Oregon
Pathetic customer service
I've been having issues with my LP gas detector going off so I did a search in the forums and came across this thread.
My 27FB is a 2007 model and I figured the detector is the original and I should replace it. Supposedly, the Atwood model 36720 is one replacement. However, I did a search and an online retailer (RV Parts Country) indicated the model 36719 replaced the 36720.
I decided I'd call Atwood to see what the actual story is. I tried their tech support number and went through voicemail hell to no avail (hang up and call another number). So then I tried their "regular" number only to go through pretty much the exact same maize. You listen to 7-8 options before getting to one that says if you are an RV owner "press the #1", which I did. What does that do? You are greeted with a response to hang up and call another number. I decided I'd skip another trip through that maize and tried to call RV Parts Country.
It may just be me, but I was incredibly irritated to get a voicemail message that "they have decided the best way to respond to customers was for customers to hang up and contact them through their e-mail/customer support option at the top of their web page".
I decided I'd go ahead and send them an e-mail that requiring a consumer who is trying to get information so they can make an informed purchase from them to go through their e-mail system to get that information is asinine and because of that I would not be making any purchases from them in the future.
Having said all that, does anyone know if the Atwood model 36719 replaced the model 36720?
Thanks in advance.
andyherman is offline   Reply With Quote
Old 11-21-2017, 02:28 PM   #27
Boxite's Avatar
2008 22' Sport
Thanks in advance.
That story is backwards... the 36720 replaces the 36719. Check the mfr'g date on whatever unit you purchase as they have limited shelf-lives and are worthless after 7 years.
Rambox
Pex fitting leak - toilet supply line eberrobw Sinks, Showers & Toilets 9 04-13-2012 10:55 AM
Where Is My Leak? Chaplain Kent General Repair Forum 6 10-07-2011 12:55 PM
Frustration !!Water leak at front of trailer!! william Haym Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-06-2011 12:41 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 08:43 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 06:42 AM
