Old 12-17-2012, 05:24 PM   #1
1973 Argosy 22
Shepherdsville , Kentucky
LP tanks
I feel silly having to ask this question but this is the place to ask it. Are the LP tanks for the outdoor grill the same as the ones for RV's?
Tom S is offline   Reply With Quote
Old 12-17-2012, 05:29 PM   #2
nilesrob's Avatar
Marietta , Georgia
Images: 12
Same fuel, same connector, different size.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 12-17-2012, 05:30 PM   #3
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Yes, except RV people often prefer larger tanks.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 12-17-2012, 05:48 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Previous posts at AIRForums guided me to install a Y-fitting on my tanks. I now have a secondary hose from my Safari's tanks that allow me to run a propane grill (minimal draw) off my main trailer tanks. Pictures to follow... Don't have the Airstream in my icy driveway at this time of year.
I'll try to post them here later in the week.
5 meter Langford Nahanni
Old 12-17-2012, 07:09 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Bob, where did you connect the "Y" fitting that you installed for your outside connection?
I've been thinking about doing just that on ours.
Is there a quick connect fitting that can be used or do we need to use the standard BBQ thread fitting ??
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-21-2012, 11:24 AM   #6
rogerdodger's Avatar
Fresno/Clovis , California
You can get it in a package including a hose. It is called Extend-A-Stay. I think I got mine at campingworld years ago.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 12-21-2012, 11:44 AM   #7
timmaah's Avatar
1999 25' Safari
On , the road
I added mine under the A Frame.. there was already a connection there. Finding the proper connections was a major pain.
This is after the pressure regulator, so I also removed the pressure reg. from the grill.
Propane Quick Connect | WatsonsWander
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 12-21-2012, 09:11 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
There are two ways to do this, Timmah's is perhaps the better way. The extend-a-flow places a T in the high pressure line before the regulator and works with a somewhat wider selection of propane grills, but is more fiddly because liquid propane tends to accumulate in the hose.
