Old 02-09-2016, 09:47 PM   #1
Opelika , Alabama
LP Tank switcher - how to install?
My recently purchased 1991 Excel 34' has two propane tanks on the front with what appears to be a manually operated valve controlling which tank is supplying propane to the RV. But above the stove, on the control panel, there's a rocker switch for LPG1 and LPG2. I'm in the beginning of a complete teardown and wonder how I can control the LGP source from that rocker switch rather than having to go outside. Currently there appears to be no wires running to the propane tank switcher dooflitchy. Here's some pictures:
ID:	257087   Click image for larger version
racecannon is offline   Reply With Quote
Old 02-09-2016, 10:04 PM   #2
1974 Argosy 20
Kooskia , Idaho
The control panel switch only allowed you to check the propane level in the tanks, not switch tanks. The original tanks (apparently changed now, as there is no wire to the tank you say) had gauges in them. After the valve systems were changed to the new OPD type, for a while there were no gauges available. I think tanks with electric gauges are now available though.
But it never allowed switching tanks by remote control.
Old 02-09-2016, 10:50 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
our 1999 34' has the 'gauge' type and pressing the button you mention, gives a fairly accurate LP fuel level. If your tanks were replaced with NON gauged type, then someone may have 'tucked' the wire ends somewhere... or cut them.. Have a look under the frame...
I added a SAE insulated and keyed two wire connectors.. look like small trailer lighting connections.. makes it easy to disconnect the tanks for refill. I believe LP1 is the Street side, LP2 is the Curb side..
We also have the same dual supply, manual selection valve and regulator assembly you do. The 'lever' points to the active supply input. You can install an "automatic switch over" which will swap to the full tank when the pressure drops on the active tank.
You CAN buy the tanks with the sensors from AS dealer ... but there is a far cheaper way... PM me for details.. (I have no financial or personal interest in the tank company.. just trying to save folks $$ and increase satisfaction)
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-04-2016, 09:22 AM   #4
Sneaky
sneaky's Avatar
2002 31' Land Yacht 30
Indian River , Michigan
I am looking to do the same thing on my 2002, 75th Anniversary Landyacht. Everything is currently working fine, but we use it even when parked at home and it would be so much more convenient to run off of external tanks when parked and save the factory installed tank for travel or back up. Any help would be greatly appreciated. Thanks, Sue
sneaky is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
HDMI Switcher with 3 inputs ghaynes755 Audio, Video & TV 1 04-29-2014 08:42 PM
Stereo Speaker Switcher JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 10-18-2013 11:54 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
