LP tank Re qualifying?
I haven't noticed any noises of any kind from the Worthington aluminum LP tanks on either my '64 Overlander or '78 Minuet. The Overlander has three-year-old 40 pound Worthington aluminum LP cylinders that came with the new OPD style valves while the Minuet has original 20 pound LP cylinders that were fitted with new OPD valves when the tanks were recertified about 18-months ago. While I haven't noticed it having been discussed lately, there was a problem with some valve switch-overs using OPD valves with the incorrect dip-tube length (the aluminum cylinders use a different valve when compared to the same capacity steel tanks) - - I don't know whether an incorrect dip-tube length could cause audible noise or if it might be OPD valves of varying manufacture having different operational characteristics.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
1978 Argosy Minuet 6.0 Metre
