Old 08-09-2011, 12:04 AM   #1
1968 20' Globetrotter
1957 22' Flying Cloud
Tracy , California
LP tank noise
I have an aluminum LP tank on my globetrotter. When I'm walking around inside I can hear something ticking and rattling inside the tank. It's driving me crazy. Can someone tell me what's going on. Thanks for the help. Mike
Rickman4 is offline   Reply With Quote
Old 08-09-2011, 01:02 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
There's a float in there that's part of the overfilling prevention device.
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 08-09-2011, 01:12 AM   #3
Tracy , California
Thanks. Is there anyway to stop the noise. Could it be broken?
Old 08-09-2011, 07:25 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Some of the OPDs do rattle a little bit, but still seem to work. (The ones I don't like are those that get stuck in the closed, "up" position, making it necessary for me to konk them on the ground a few times.)
If you are going insane with it, then two suggestions:
1. Put some stabilizers on the front to limit movement; or
2. Spend some money and have the valve replaced.
Lynn
WBCCI 21043
Old 08-09-2011, 08:13 AM   #5
dznf0g's Avatar
Oswego , Illinois
If your bottles have the fuel gauge on the top, there is also a second float assembly in addition to the OPD float.
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
69 Overlander water tank swap colin57 Waste Systems, Tanks & Totes 2 04-24-2011 08:23 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
