Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 08-16-2002, 09:02 AM   #1
kzener40's Avatar
Profile:
Images: 14
LP Tank Mounting bracket
I own a 1956 Bubble. The original mounting brakets for the LP tank on the hitch was removed prior to me buying it. Can someone take a picture of their mounting bracket so I can see how I need to build a new one. Has anyone done this before and if so any words of advice? My trailer is only 15' so I'm only putting one tank on. Not sure if it originally had two or not but think one should fit the bill.
Ken
kzener40 is offline   Reply With Quote
Old 08-21-2002, 05:40 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Ken,
You might want to take a look at the vintage archives picture site here
http://www.vintageairstream.com/arch...756Bubble.html
Most of these seem to have come equipped with one tank. There looks like there used to be a plate between the frame rails that acted as a platform for the small tank. Some of the units pictured also seem to have a basket for the tank. If the plate is still there then it is just a matter of fashioning a mounting system. If the foot of the tank has holes in it you coudl just clamp it to the steel plate using threaded hooks and bolts???
You may wnt to wander on an RV lot an look at how the single tanks are mounted on a pop up. Silver spray paint and no one will know the diff.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
HELP - Need to empty LP tank for export 1985air345 LP Gas, Piping, Tanks & Regulators 4 03-29-2004 11:53 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 09:16 PM
LP Regulator leak? 3Ms75Argosy LP Gas, Piping, Tanks & Regulators 5 04-29-2003 09:41 AM
LP tank switchover Silvertwinkie LP Gas, Piping, Tanks & Regulators 6 03-12-2003 06:20 PM
Vintage Oval Shaped LP Tank Cover smily LP Gas, Piping, Tanks & Regulators 3 12-20-2002 05:52 PM
