Old 08-21-2002, 05:42 PM   #1
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
LP supply line
My 71 Tradewind is getting a new LP gas lines, from the regulator on back to under the midle of the trailer. I believe it is a 5/8" copper line, with a flexible line terminating at the regulator.
Mine has so many dents and kinks that it does not seem very safe anymore.
especially the part underneath the tongue has suffered from the effects of jack stands and who knows what else.
My question surrounds the flexible line going down from the regulator to the L junction where it meets the copper line. I removed a corrugated hose, that reminds me of a gas dryer type supply line, only bigger in diameter. Is this what goes there? What do you guys use on your trailers?
Uwe
www.area63productions.com
Old 08-22-2002, 12:33 AM   #2
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Size?
John,
thanks for the suggestion. I think I read the other thread you were referring to a while back.
Is your rubber line the same diameter as the copper line? My copper line is 5/8 or 3/4, haven't measured it yet.
I took it off completely, and can not believe that propane would even still pass through it.
I am going to be looking for a rubber line like yours to go from the copper line up to the regulator. I wonder if it is readily available or if it has to be specially made?
Uwe
Old 08-22-2002, 03:37 AM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
My original connections at the regulator were also the corrogated copper. I have all new rubber hookup now, including a new auto switching regulator. The hoses are readily available and DOT approved for travel trailers. http://www.campingworld.com or any good parts stocking RV store will have them. Some states codes also require a protective shield on the regulators for new installations. About $4.00.
What I find interesting is they used copper tubing for your 71's header line under the trailer. My '65 Globetrotter uses black carbon steel pipe header with copper tubing branches to the appliances. Much stronger than tubing and less prone to damage. I have not crawled under any newer ones like yours and maybe someone else can tell us that this is the practice now. I went back with pipe, like the original.
I would not cover gas lines in any kind of foam insulation. If a gas leak occurs it will travel along the tubing or build up in the covering. The reason it is under the trailer exposed is so that you can inspect it each day during your travels and any leaks that do occur will dissipate into the air and not build up lessening the chance of explosive containment. The only place it is okay to cover is were the tubing makes penetrations into the body and this is to prevent chafing through the floor penetrations. AirStream used short little pieces of black rubber hose slid over the copper tubing.
Best Regards;
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 08-22-2002, 04:39 AM   #4
lynn's Avatar
From the regulator to main gasline (5/8") on new trailers have a LP Association approved rubber hose. Most of the new trailers have the main gas line covered with plastic water line to protect it from road damage. In the old days a corragated hose was used from regulator to main gas line. :-)
lynn is offline   Reply With Quote
Old 08-26-2002, 06:33 PM   #5
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Unhappy L P Supply line
Got the same problem uwe. I bought new line from CW to replace the old corrigated line to main. There is a flair el at that end. New line doesn't fit el flair!! Can't find the right fitting. I need a reducing el, or combo of fittings. Anybody got solutions???
niftypkg is offline   Reply With Quote
Old 08-27-2002, 08:13 AM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
No fit!
I went searching EVERYWHERE last week for a new line, with absolutely not even a smidgeon of luck. Home Depot, Lowe's, Camping World, Airstream, RV Repair, RV Repair, RV Repair, RV Parts, Trailer Supply - - - nothing.
It is a 5/8 flare fitting on both ends. I have a few more places to check yet, but essentially I am going to have to have one made. I hate the thought of using 2 adaptors to make some other line fit.
I made up a new copper main supply line, and everything is nice and shiny to the L-fitting. I will keep you posted on what will transpire.
Uwe
Old 08-27-2002, 11:48 AM   #7
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Gas Line
here is a picture of the gas line in question
Uwe
Old 08-27-2002, 03:35 PM   #8
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
LP supply line
UWE, I replaced the old regulator with a new automatic, and I replaced the line with a rubber one from CW. I used a new fitting at the top. It fit the swivel end of the new line. At the bottom the new line doesn't fit the old LPflair, which is an el flair. So I need a 5/8 flair to a 1/2 reducer. May have to go to pipe and then 1/2 flair. If you want to keep the old reg. you should be able to find a 5/8 double ended flex pipe. Try an appliance store. I also replaced the cylinder lines with the new wrenchless lines.
Old 09-17-2006, 04:12 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Just found this old thread...which remained unresolved.
A very kind form member sent me an original and perfect gas line to replace my old one. It was a perfect fit. This is a Rego regulator, btw.
I sold this trailer (1971 Tradewwind) over a year ago, btw. Got me a 1963 Overlander to replace it.
Uwe
Old 06-17-2009, 02:49 PM   #10
1972 31' Sovereign
emeryville , California
looking for the same line
Hello there,
I have run into the same problem and need to replace my accordion metal hose. I can't seem to find even what it's called to replace it. Did you, in you research, find what would fit? Would 5/8 double end work without adapters?
Henri
emmahesse is offline   Reply With Quote
HELP - Need to empty LP tank for export ViewRVs LP Gas, Piping, Tanks & Regulators 7 03-16-2010 07:23 PM
New LP Supply line? themostbob LP Gas, Piping, Tanks & Regulators 0 05-01-2003 09:35 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
LP Hose from Reg. to Trailer niftypkg LP Gas, Piping, Tanks & Regulators 2 06-20-2002 09:09 PM
