Old 11-03-2005, 09:01 PM   #1
walter1's Avatar
1964 22' Safari
Foresthill , California
LP lamp mantles
I have a Humphrey / Paulin propane lamp. It uses the L13-6 tie on mantle. They break a lot due to vibration. Can I use Coleman lantern mantles? They are readily available while traveling.
walter1 is offline   Reply With Quote
Old 11-04-2005, 06:32 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
If they fit, go for it! Do a google search for gas lights. I seem to remember a sight that had some heavy duty mantles for indoor fixtures somewhere on the net.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-06-2005, 10:55 PM   #3
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Walter1, I use, I mean used Coleman mantels in my SOB. It had a Humphrey gas light. They worked fine. Never had a problem with them breaking/falling apart.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 11-07-2005, 04:56 AM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
walter1,
You might find some of the Coleman mantels at your favorite Wally's world to have metal clips in the top seams..Just remove that and, slip/tie the mantel over the Humphrey's opening..It worked for me.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-07-2005, 07:39 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
YES. Check out post # 118 on the "new challenge" thread.
Old 11-07-2005, 11:48 AM   #6
walter1's Avatar
1964 22' Safari
Thanks, I'll try them, any way to keep them from breaking in transit?
Also the globe has been known to come off. Any way to keep that set screw tight?
Walter1
Old 11-07-2005, 12:29 PM   #7
Well Preserved
1993 21' Sovereign
Walter1
Coleman doesn't seem to be as fragile as the originals, I will let you know how long the one I installed yesterday lasts.
Try some blue LockTite on the threads of the set screw.
DON"T USE RED. It will NEVER come off.
Want to add b/room reading lamp Cedars General Interior Topics 3 10-01-2005 05:12 AM
Picked up the 59 today!!!! 59toaster Our Community 9 02-16-2003 03:16 PM
A/C and Furnace Charles Q Treichel Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-05-2002 04:20 PM
