Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 10-28-2005, 02:18 AM   #1
ipso_facto
Profile:
LP hoses
Where do I get the 2 hoses that go from the LP tanks? They are a couple of feet long but seem to short, as at the very bottom it's bent so badly that sometimes that my hot water heater and furnace cut off. Especially one of the tanks.
I only wonder if these came with the unit or where installed by PO.
1986 Excella, 32' - FOR SALE ON EBAY, AUCTION # 160034864277
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 10-28-2005, 02:34 AM   #2
nickcrowhurst
Profile:
Ipso, I presume you are referring to the flexible rubber pipes from the LP tanks to the regulator. These should be replaced every few years as they harden and start to show signs of cracking. They are usually fitted with a label which shows the year of manufacture. Other good reasons to change yours are that the design changed a couple of years ago, so that the connection to the bottles, (when the bottles are fitted with OPD - Overfill Protection Device- valves) is with a right hand threaded large plastic connector. This is tightened by hand, and no wrench is required. The connectors also have safety features, in that a fire will seal the gas flow. The pipes should run uphill to the regulator, so that oils in the tanks will not contaminate the regulator. The pipes are available in various lengths from Airstream dealers, RV supplies stores, hardware stores for barbeque grills, etc. They are not specific to Airstreams.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-28-2005, 08:13 AM   #3
Mookie
Mookie's Avatar
Profile:  1992 21' Sovereign
Oakland , California
Images: 59
I had a similar problem - my tanks were empty and I needed to upgrade to the new OPD valves. In order to take advantage of the safety features of the OPD valves, you also need to upgrade your hoses. My hoses are 36 inches long and I was having difficulty finding the new style hoses in longer lengths. I finally found them here:
http://www.pplmotorhomes.com/parts/lp-gas/lpg-hoses.htm
The prices are reasonable and they ship quickly.
Hope this helps.
-Mark
Mookie is offline   Reply With Quote
Old 10-28-2005, 08:48 AM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
My Airstream still has the copper connections with POL fitting between the tank and regulator. They are OPD compliant tanks, but you can still use a brass POL male fitting to connect to an OPD tank. Most propane distributors can make these up for you if you desire. I usually get a year or more out of a set of tanks so having to use a 7/8" wrench to disconnect tanks is not much of a hassle.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-28-2005, 06:59 PM   #5
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
Every couple of years? Is there anything that can be used to treat or protect the hoses to prolong their life? Mine are under cover, so I'm hoping they last longer.
SilverRanger is offline   Reply With Quote
Old 10-28-2005, 11:13 PM   #6
nickcrowhurst
Profile:
303 Protectant, available from Auto stores and RV stores is excellent.
Nick.
Old 10-29-2005, 04:59 AM   #7
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
It depends on where in the country you live, and whether you store your trailer outdoors, or if the front of the coach is shaded when stored outdoors. UV causes the rubber hoses to deteriorate, just like the rubber in your tires. I personally see no need to replace them on a set timetable, but I do replace them at the first sign of cracking.
Change is inevitable, except from a vending machine
AIR#2611
Old 11-11-2005, 07:46 AM   #8
Swanny
Swanny's Avatar
Profile:  1990 34' Excella
Windcrest , Texas
When in doubt replace your hoses
I had noticed a propane smell near the front of our AS. I completed the 'bubble-test' to see if I could find a noticeable leak and found none. By the way, this test is done by mixing dish soap with water in a spray bottle. You than spray this on the area you suspect is leaking and watch for bubbles to develop. Of course the soapy water will bubble a little bit, but if you have a leak you will find it this way.
Anyway...no leak was found, so I replaced the hoses connecting each tank to the regulator. I also upgraded to the outside threads which allows us to remove the tank by hand instead of using a wrench. The cost of the two hoses was $42 for both from a local RV shop.
The great news is there is no gas smell and as the guy at the store mentioned, these hoses are pure rubber. There is not an internal casing, so once the rubber gets old, the propane will leak through the hose. Hope this helps!
Mitch
Texas Streamer
1990 Excella 1000---34'
WBCCI #18303
2005 F-350 Diesel 4 X 4
Swanny is offline   Reply With Quote
Old 11-11-2005, 08:24 AM   #9
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Another thing you will want to watch and check for is Rodent damage to the hoses, I have actually had a hose punctured by a squirrel knawing on it. It happen twice to the same hose! So I got a piece of heavy vinyl tubing to slip over the LP hose to protect it. I have also seen stainless steel braided hoses...they would look mighty sharp on an Airstream, but I suspect would have to be custom made....
Aaron
WBCCI #2449 AIR #2495
Old 11-13-2005, 06:15 PM   #10
Swanny
Swanny's Avatar
Windcrest , Texas
Volatile Squirrel
Aaron
Now that's a squirrel I'd stay away from with matches
Mitch
Texas Streamer
WBCCI #18303
Old 11-15-2005, 11:40 AM   #11
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
(Drum roll ......)
Did the squirrel get gas?
(Cymbal crash!)
>>>>>>>>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 01-23-2006, 04:43 PM   #12
Byron71
Byron71's Avatar
Profile:  1971 18' Caravel
Fort Collins , Colorado
High pressure vs Low pressure hoses.
Anything that is down stream of the regulator would be low pressure?
For instance the main hose coming from the regulator going into the trailer is low pressure right???
Byron
Byron71 is offline   Reply With Quote
Old 01-23-2006, 06:01 PM   #13
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Byron
Correct. The line(s) from the tank(s) to the regulator are high pressure. Everything else is low pressure.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 01-23-2006, 06:24 PM   #14
Longhorn57
Profile:  Austin , Texas
No gas to heater / refrig
The hoses on our 1976 Caravanner have been upgraded and the tanks just filled. The heater came on for about three hours and then quit and I cannot light the refrigerator. Do you think this has something to do with the new hoses?
Longhorn57 is offline   Reply With Quote
Radiator Hoses for 454 fwiz Mechanics Corner - Engines, Transmission & More... 8 07-26-2005 05:29 PM
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 6 12-24-2004 08:44 AM
Water hoses ALANSD Mechanics Corner - Engines, Transmission & More... 8 01-26-2003 10:46 AM
What Water Hoses to Bring? rmmm68 Fresh Water Systems 7 01-14-2003 07:39 PM
Tune up and... ALANSD Mechanics Corner - Engines, Transmission & More... 20 07-26-2002 04:55 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
