Old 11-17-2015, 05:16 PM   #1
2012 27' FB International
LP gas tank handle stuck in closed position
Hello all, I am somewhat of a newbie to these forums. The on/off valve handle to one of my LP gas tanks is stuck in the closed position. I have tried with the tools that I have to dial it open but cannot. Does anyone have an idea what might be going on and/or what the fix might be. This happened once before and I had an airstream dealer open it, but I neglected to ask them how they did it. Any advice is appreciated!
flyingfishy is offline   Reply With Quote
Old 11-17-2015, 05:34 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
You might want to contact a propane seller & ask for advise.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is online now   Reply With Quote
Old 11-17-2015, 06:07 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You absolutely do not want to break anything trying to open it, so if you can't open it by hand, don't mess with it. Even an "empty" propane cylinder is full of vapor and makes an excellent bomb. A propane seller will have non-sparking tools to use on a stuck valve so the problem doesn't blow up in your faceó literally.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-17-2015, 07:15 PM   #4
Thanks mrjkq, I will contact a propane dealer.
Old 11-17-2015, 07:35 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Not a bad idea to have somebody else do it. There is probably little chance that you'd create a leak. However, the valve stems on those valves are surprisingly small and made of brass: It isn't that hard to break the stem off. And then you do have a bit of a problem on your hands.
If this turns out to be a consistent problem hereafter, your best best may be simply to have your dealer replace the valve with a new one.
Lynn
WBCCI 21043
Old 11-18-2015, 03:01 PM   #6
gainesville , Virginia
Don't the off/on valves on prophane tanks turn in the opposite direction of most (waster spigot, etc.) valves? Could this be the problem?
GEEEER is offline   Reply With Quote
Old 11-18-2015, 03:46 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
You may be thinking of the POL fittings on valves, which are left-hand threaded. (Note that the newer ACME fittings have the large, right-hand threads, but these valves also always include internal, left-hand threads as well.)
Acme or POL valve required for RV propane cylinders & cylinder re-certification - RV Basics .com
Lynn
WBCCI 21043
Cabinet Door Latch Locked in Closed Position John4str General Repair Forum 5 09-20-2015 01:48 PM
Bed stuck in the UP position - HELP! time2play 2011 - 2015 Classic (all lengths) 12 09-28-2014 06:44 AM
Help! Bed is stuck in up position! Honeybadgers General Interior Topics 8 07-05-2014 08:31 AM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 04:30 PM
interior cabinet latch stuck closed in 63 trotter ChicknKathy Cabinets, Counter Tops & Furnishings 5 03-04-2008 09:52 AM
