Old 11-01-2014, 07:22 AM   #1
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Winston-Salem , North Carolina
LP Gas Furnace
OK, went through the posts that could relate to my problem: gas furnace on my 1994 Excella is not lighting, fan turns on when you turn the thermostat on, but no click, no ignite, no warm air. Plenty of gas to all other uses in the trailer. Worked fine when we pulled in and set up, in fact it wouldn't cut off when the temp was reached, just kept running. This was a first. Cut the thermostat off. Later when restarting it wouldn't. To me this says circuit board, maybe thermostat, maybe both.
My real question is where the heck do you get said issue fixed when you are in southeast Utah/northeast Colorado? Especially on a weekend. Running the small built in catalytic and a small electric heater right now, so OK, but need to get this fixed.
Raconteur, Bon Vivant, Curmudgeon, and other depending on Susan's mood at the time...Retired, so don't ask me to do a damn thing
oledawg is offline   Reply With Quote
Old 11-01-2014, 07:43 AM   #2
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Many years ago my furnace quit on a deer hunt in south Dakota. It was really cold and snowy, and my choices were limited.
My generator worked, to I plugged in a 1500 W electric heater, set it front of the cold air furnace intake, and ran the furnace fan. It was a bit chilly, but warm enough to live in for the rest of the hunt.
terryV is offline   Reply With Quote
Old 11-01-2014, 07:55 AM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Check the sail switch in the fan duct.
Old 11-01-2014, 08:06 AM   #4
"Sassyfras"
oledawg's Avatar
1994 30' Excella
And where might that rascaly fan duct be? I have never messed with the furnace so point me in the right direction. Thanks.
Old 11-01-2014, 01:43 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It may be time to pull the furnace and get it bench tested. The sail switch is in the furnace housing. It's just a simple piece of tin attached to a little switch that tells the circuit board that there is blower air. I think it purges or blows air to purge any propane around the heat exchanger and then the circuit board says ok to ignite. No clicking would indicate the sail switch didn't work. But I can't imagine how to test it without taking the furnace out.
Removing the furnace isn't too bad. You may be able to disconnect the propane line, outside vent cover and electrical plug, then slide the innards out of the housing saving some time. Note: You gotta enjoy working in tight places while laying on the floor. Most RV shops can bench test it for you and make the repairs to get you warm air again. With the furnace out, you can test the sail switch.
A new furnace isn't the most expensive appliance in your trailer. I think they are in the $700 range. I found my old furnace became unreliable and I just gave up on it instead of the $200 repair bills.
David
Old 11-01-2014, 03:11 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
My, my, you really are in the middle of nowhere, aren't you?
Your furnace system is not Airstream specific so any qualified RV dealer (and possibly quite a few home heating/cooling shops) should be able to look at it for you. I'm sure that there must be some of these outfits in Flagstaff, Durango or Farmington. None of these are "down the road" but that's what you get for trying to be adventurous!
Bob Martel
WBCCI# 5766
Old 11-10-2014, 10:48 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
result?
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-12-2014, 12:49 AM   #8
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Well, not worrying about it since the small 1500 watt space heater is keeping everything warm enough. Decided to address it when I get back to NC. Sounds like the sail switch is the likely culprit.
Old 11-15-2014, 06:25 AM   #9
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Guess what? Furnace is now working after a 10 mile trip down a one way gravel/dirt washboard road in the Coconino National Park that my GPS sent me down. Perhaps the sail switch was stuck and became unstuck ;-)
Old 11-15-2014, 07:14 AM   #10
Chelsea , Michigan
Images: 12
I remember as a kid whacking the side of the television when it was acting up. That usually fixed the problem. Perhaps by driving down a bumpy road you did the same thing!
Bob Martel
WBCCI# 5766
Old 11-15-2014, 07:46 AM   #11
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Gas on, gas off? heavyjumbo LP Gas, Piping, Tanks & Regulators 28 07-23-2011 07:59 AM
What fitting for GAS on Atwood gas/elec WH rlindberg Water Heaters, Filters & Pumps 1 04-09-2010 11:29 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Gas or No Gas, that's the question... oldtrucksrul LP Gas, Piping, Tanks & Regulators 14 11-16-2008 10:29 AM
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
