Old 05-17-2014, 11:27 AM   #1
2003 28' Classic
Ladysmith , Wisconsin
LP Gas disconnect
How do you disconnect the small LP Gas wire ? Click image for larger version
Name:	ImageUploadedByAirstream Forums1400347581.996917.jpg
ID:	212104 I Does it separate at the pink clip ? Seems stuck.
JacobMerridy is offline   Reply With Quote
Old 05-17-2014, 11:38 AM   #2
Missouri Valley , Iowa
The pink clip you refer to is a male and female spade connector. They should pull apart. Mine are difficult at times also. Maybe a shot of WD-40 would make it easier
to separate.
Dan
Farmer Dan is offline   Reply With Quote
Pictures of quick disconnect gas line mounting. RLS LP Gas, Piping, Tanks & Regulators 2 08-31-2008 08:28 PM
Solar and the Disconnect Switch/Charging/Phantom Loads Xray Generators & Solar Power 9 01-23-2005 11:55 AM
Disconnect Electric Hitch Jack?? luckydc 1997 - 2004 Bambi 12 04-01-2004 06:40 PM
Disconnect Drive Shaft smily Airstream Motorhome Forums 2 02-23-2004 05:51 AM
