View Poll Results: How do you fix a beeping LP gas detector?
Install a new one 0 0%
rewire the old one 0 0%
buy new batteries 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 05-07-2011, 03:55 PM   #1
2006 19' International CCD
White Stone , Virginia
LP gas detector beeping
Our LP gas detector is beeping. It is blinking green, showing it has power, and there seems to be no problem with the batteries. This is the third time this has happened to us. I think they replaced the unit before (not sure). How can we fix this? Can we replace it ourselves? What makes it happen?
severt is offline   Reply With Quote
Old 05-07-2011, 04:18 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Not trying to come off as a smart a$$, but I'm reminded of an old high school shop instructor who's favorite saying was..."If all else fails, read the instructions!"
If you don't have the Mfg's booklet with your trailer stuff, you should be able to find the info on the Net - check the Make, model, etc. - they should have notes about your particular salutation...
If it's defective, it's not that big of a deal to replace it yourself...
Ray & Pat; Morada, CA
Old 05-07-2011, 04:19 PM   #3
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Check your battery voltage
jkcru is offline   Reply With Quote
Old 05-07-2011, 04:34 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the forums! You're in the right place for all things Airstream!
You might try holding down the button for a bit...ours goes off periodically and that resets it. Part of the problem in the 19' Bambis is its location — right next to the furnace vent...that can be a good thing or a bad thing.
TB & Greg and Abbey Schnauzer
#3954
Old 05-07-2011, 06:05 PM   #5
Gainesville , Florida
yes, check your battery voltage. jim
Old 05-07-2011, 08:28 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
If you check the manual or the back of your LP detector, you will see that EVERY LP detector SHOULD BE REPLACED AFTER 5 YEARS! The reason being that the sensors loose their sensitivity and do strange things, like go off for no reason, or not at all.
I would suggest after verifying the 12VDC circuit, I would get yourself a new LP detector.
Old 05-08-2011, 06:53 PM   #7
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Lew, once again, you've solved a problem for me. As always, thanks for the advice.
UAPachyderm is offline   Reply With Quote
beeping gas detector, lp alarm
No Gas to range cuyd Stoves, Ovens & Microwaves 22 06-27-2011 07:09 PM
Gas, Diesel, 6-speeds r carl Tow Vehicles 51 04-01-2011 10:03 AM
How can I fill my US Ali gas bottles with LPG in the UK??? shinny67 LP Gas, Piping, Tanks & Regulators 7 01-14-2011 09:42 AM
