Old 12-06-2014, 09:08 PM   #29
Maniacal Engineer
barts's Avatar
Menlo Park , California
If tight bends need to be made and the piece of tube is removeable when bent, filling it w/ fine sand and taping the ends over w/ duct tape will support the tube during the bending process.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 12-06-2014, 09:12 PM   #30
2007 22' International CCD
Or you can get spring benders that go over the tube to prevent linking when you bend it tight.
KE4GNK/AE
Old 01-11-2015, 04:32 PM   #31
1975 25' Tradewind
Aunsin , Texas
I am an extreme novice ( or was) when I installed my water heater replacement. It required some serious tube bending - almost 90 deg at about a 2" or 3" diameter. Spring benders saved my bacon- takes patients tho!
Bwilson11 is offline   Reply With Quote
Can a Ford Flex tow an Airstream Nigel Tow Vehicles 204 12-01-2013 06:47 PM
LP flex line quality walter1 LP Gas, Piping, Tanks & Regulators 0 08-21-2007 11:17 PM
"Water Heater" & SS Flex hose? Sneakinup Water Heaters, Filters & Pumps 15 01-31-2004 09:22 PM
