Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 11-10-2010, 11:44 AM   #1
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
lp black stuff
When I disconnected my tanks, a black or very dark brown oilly or tar looking substance is dripping out of the hose.
What is it and Why?
GeocamperAS is offline   Reply With Quote
Old 11-10-2010, 11:49 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
What is it and Why?
There is a substance added to LP to give it the distinctive onion odor, This stuff accumulates in the tank over the years and that is probably what you are seeing.
You will also notice you may get some odor from your stove when running on an almost empty tank even though you don't have a leak. \Not sure why it is showing up in the hose
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 11-10-2010, 01:29 PM   #3
It could also be from condensation sitting in the rubber hoses and deteriorating them. The hoses should be routed so there is no place for water to collect in the rubber hoses if possible.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 11-10-2010, 02:46 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
What is it and Why?
Small amounts of lubricating oil are added to propane by refiners and marketers to prolong the life of pumps and valves used during distribution. Since the oil does not vaporize, it accumulates in the tank over the course of time.
If it's in the hoses it's because some liquid propane got into the hoses at some point. The liquid propane carried the oil along with it and then when the propane vaporized the oil was left behind. This could be a result of the tanks being overfilled, or using the tank in the wrong orientation (vertical tank used horizontally or upside down, for example), or just from propane splashing around while going over rough roads with the fridge on.
The regulator should be above the tanks, and the hoses should slant down toward the tank valve, so that any liquid that accumulates runs back into the tank.
Methyl mercaptan is the substance used as an odorant. Because it boils at 43 degrees F. it will not accumulate in liquid form except in cold weather. Trace amounts present in the lubricating oil may be responsible for any accompanying stink.
WINTERIZING ISSUES-Black "ink" stuff Harleyjohn Waste Systems, Tanks & Totes 8 10-24-2010 11:59 AM
Looking for stuff Apache_Camp All Argosy Trailers 1 08-25-2009 10:45 PM
Black stuff in the frig flyguy Refrigerators 11 05-24-2008 09:12 AM
I need some stuff mtnman All Argosy Trailers 20 12-11-2005 06:45 PM
