Old 12-28-2014, 09:09 AM   #1
1988 29' Excella
Plant City , Florida
LP and Carbon Monoxide alarms
I've been looking at different LP and CO monitor alarms there are a lot if them on the market and the reviews on most talk about false alarms and backup battery life could anyone recommend a good monitor
Joe
wjcwill is offline   Reply With Quote
Old 12-28-2014, 09:11 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Kidde (the fire extinguisher people) make decent CO and smoke detectors.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-28-2014, 01:52 PM   #3
1988 29' Excella
Thanks I see that Kidde has a combo LP and CO alarm reviews are pretty good too
Old 12-28-2014, 02:46 PM   #4
There is one problem with a combined LP and CO detector. It's meant for use with compressed natural gas (CNG) in a home, not propane in an RV. CNG and CO are both lighter than air and need detectors near the ceiling so a combined detector would work. However, propane is heavier than air and needs a detector near the floor, so a combined CO and LPG detector will not work in an RV.
You can get a combined smoke and CO detector for a ceiling mount, but you still need a separate LPG detector near floor level.
WBCCI #1105
TAC LA-4
Old 12-28-2014, 09:21 PM   #5
1988 29' Excella
Thanks I did not know that I will get separate monitors
Old 12-29-2014, 04:35 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
12 volt dc carbon monoxide and LPG alarm by saft Alert for rv's. Replaced with Atwood part number 36636 and is 79.95 and is a duel alarm for LPG and Carbon monoxide for Rv's.. A home one would be 120 volts...originally these were separate .Get updated..
Old 12-29-2014, 05:00 PM   #7
Originally Posted by tjdonahoe View Post
Get updated..
Just because they make one "for RVs" doesn't change the laws of physics. Propane is still heavier than air, and you need a detector near the floor. Carbon Monoxide is still lighter than air, and you need a detector near the ceiling. No amount of marketing will change that.
On Edit— Marketing can't change the laws of organic chemistry, either. Forget being blown up by a buildup of propane. You'll get permanent nerve damage from breathing propane long before enough builds up to blow up. Propane is toxic to breathe at 10% of the lower explosive limit. Guess what… LPG detectors sound an alarm at 10% of the lower explosive limit. By the time the alarm sounds, enough has built up to hurt you. Now don't you want your LPG detector at floor level, so that it can detect harmful buildups before they get up to the level of your nose and you're breathing the stuff?
WBCCI #1105
TAC LA-4
Old 12-29-2014, 05:13 PM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
It is on the floor!!! The smoke alarm on the ceiling. May be my dog has been damaged as he can set my LPG alarm off....
Old 12-29-2014, 05:27 PM   #9
Then you've got the opposite problem. Carbon monoxide is still lighter than air and still deadly to breathe and the detector for CO needs to be on the ceiling with the smoke alarm, not down on the floor with the LPG detector.
It's okay to combine smoke and CO detectors. It's not okay to combine LPG and CO detectors. No matter whether that combined LPG/CO detector is on the floor or ceiling, it's still in the wrong place for one of the things it's supposed to detect.
WBCCI #1105
TAC LA-4
Old 12-29-2014, 06:16 PM   #10
1955 30' Liner Commodore Vanderbilt
Linden , Michigan
Where were you guys when I bought one two weeks ago???
StevieB is offline   Reply With Quote
Old 12-29-2014, 06:42 PM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Well I am not sleeping up high just a little higher than the alarm,I do think the co will start down low,near the furnace,frige or the hot water heater, so maybe one will be correct, 50 - 50 ,not bad odds. At the present time I am more worried about about the lifetime sealed wheel bearings..
Old 12-29-2014, 07:39 PM   #12
Wayward's Avatar
Cary , North Carolina
Atwood combination LP and CO detector. $64
"ETL listed and tested to UL 1484 & CSA 6.19.01 for residential and RV applications"
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 12-29-2014, 07:53 PM   #13
2016 30' Classic
Erie , Colorado
How do I install a carbon monoxide alarm?
Heat and smoke rise, which is why we place smoke alarms high on the wall or ceiling. Carbon monoxide, however, mixes with the air. For this reason, it is preferable to install CO alarms at knee level – the approximate height of a sleeping person’s nose and mouth.
If you have young children or pets that could tamper (play) with your detectors, you can move them up to chest height. Another option is to place them in a hard-to-reach area, where even curious hands and overzealous tails would have a hard time reaching. Bear in mind that a CO detector should never be blocked by furniture, curtains or other objects, as restricted airflow can affect its function.
A single-function carbon monoxide alarm is recommended, but if you are installing a dual smoke-CO detector, place it on the ceiling so it can detect smoke.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 12-29-2014, 07:53 PM   #14
It's still a bad idea, for the reasons already discussed earlier in the thread. But I'm done arguing about it. Buy it if you want it. But I for one never will. If you do buy one— and trust your life, and the lives of your family and pets to it— I hope you never have to rely on it to warn you of a real danger.
"UL Listed" doesn't necessarily mean what you think it means. It means that if the product is supposed to sound an alarm when the quantity of CO or propane AT THE SENSOR reaches a certain level, the alarm will sound. Whether that sensor is mounted in the right place for what it's trying to detect is not part of any test that UL performs.
When they say that the combined detector meets the requirements of NFPA 1192, the Standards for Recreational Vehicles, then I'll believe it and use it. Not before.
WBCCI #1105
TAC LA-4
Cautionary News Article Regarding Generators and Carbon Monoxide Poisoning Phoenix Off Topic Forum 2 11-10-2012 12:26 AM
Carbon Monoxide Detector and strange smell frscott Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-19-2009 09:22 AM
Carbon monoxide?? imagine Our Community 7 03-28-2005 03:22 PM
Carbon Monoxide: How much is too much? Lotek General Appliance Topics 3 01-08-2005 06:06 AM
LP Gas/Carbon Monoxide Detectors Joseph O. Smith LP Gas, Piping, Tanks & Regulators 28 11-02-2002 01:22 PM
