Old 05-28-2012, 07:49 PM   #1
1985 31' Excella
Santa Fe , New Mexico
Love the smell of propane
So, I'm brand new to airstream, rvs and most things mechanical. I recently acquired an 85 excella--let the fun begin.
I took it out last weekend and after cooking a little I noticed that the propane tanks smelled very strongly of propane. I turned off the gas and decided to check for leaks at home. I sprayed soapy water on all lines and connections. All lines and connections are fine.
But, this thing (see picture below) where the gas lines come together was pumping out all sorts of gas. It appears to be some sort of release vent.
My question is what is this thing? Should it be letting out gas? Could it be that I have something configured wrong?
ID:	159572   Click image for larger version
Land Grover is offline   Reply With Quote
Old 05-28-2012, 08:12 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
One hose comes in from each tank right? Then it is a leaky regulator. Get a new automatic 2 stage regulator it's due. While you are at it get new hoses too.
Old 05-29-2012, 07:42 AM   #3
1985 31' Excella
Thanks. I"ll see if I can get that thing updated.
Old 05-30-2012, 10:29 PM   #4
1985 31' Excella
New regulator, works fantastic. No more leaks. Thanks for the advice.
kris
