Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 12-14-2010, 07:24 AM   #1
westernviews's Avatar
2013 27' Flying Cloud
Livingston , Texas
Loud clicking sounds heard when the furnace is on
There are loud clunking or clicking sounds heard at both ends of my Airstream connected to furnace activity, especially it's going on or off, that seem to have increased in volume this fall. I have assumed it is some part of the propane system. Have wondered if this is a sign that some parts need to be replaced or serviced. I worry the system will break down in a cold spell and cause the pipes to freeze.
Can anyone enlighten me on what these sounds are? I am currently traveling in South Texas and not near an Airstream dealer.
Westernviews.us
westernviews is offline   Reply With Quote
Old 12-14-2010, 07:45 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
My first thought, since it is continues, is the fan blade is striking the case. There is no reason to go to an Airstream dealer, any RV shop should be able to work on the heater.
If the sound starts as soon as the fan come on that would confirm it to be in the fan since the gas valve dose not open for about 15 seconds after the fan start thus eliminating any parts relating to the gas system or the heat exchanger.
2004 Excursion 4x4
Old 12-14-2010, 08:02 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
It may be something as simple as a leaf or piece of paper caught in the blower wheel.
Old 12-14-2010, 08:21 AM   #4
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Sounds to me that it is from the duct system. You say "connected to furnace activity, especially, it's going on or off". At start-up and shut-down the duct system goes through the greatest heat changes and expansion and contraction. This quite often causes motion in the ducts resulting in "clunking" noises. When the system has warmed up to operating temperatures the noises usually quit, only to start again when cooling at shut-down. Does this describe your noises?
Sam
samb is offline   Reply With Quote
Old 12-14-2010, 09:16 AM   #5
Ottawa , ON
Mud-dauber nest?
Old 12-14-2010, 12:35 PM   #6
Livingston , Texas
Sam
If I'm lucky, it is just duct expansion and contraction sound. It is not a continuous noise, just related to the furnace turning on or off.
Thanks all.
Westernviews.us
Old 12-14-2010, 01:25 PM   #7
HowieE's Avatar
Images: 12
Thanks all.
The duct work is soft plastic tubing so I doubt it is that.
Again I would look at the fan. The fan shaft may move in or out of the motor housing during start up and shut down causing it to hit some thing at those times. Also the sail switch housing on the fan may be loose.
2004 Excursion 4x4
CO detector sounds PBStrother Batteries, Univolts, Converters & Inverters 4 06-05-2010 11:03 PM
Glitch when clicking on thread? Mackhopp Forum Admin, News and Member Account Info 20 03-09-2010 01:12 AM
A/C clicking noise Goldeneye Furnaces, Heaters, Fireplaces & Air Conditioning 14 05-15-2009 11:34 AM
Clicking noise after installing Tekonsha Envoy in 2008 VW Touareg ericwarren Brakes & Brake Controllers 1 08-01-2008 08:08 PM
Furnace questions and scary sounds in turns amathis55 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-07-2006 05:05 PM
