Old 01-20-2014, 08:44 AM   #1
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Loose Refr Igniter?
1999 Excella 30' - Mods/ feel free to redirect, and/or tell me links for the answers which I couldn't find with SEARCH. Am I correct that this little white tube should be secured by the loop-and-screw? I ask because mine is loose, and a rough road will dislocate it resulting in the Refr going to "check" rather than staying on. (View is with wind deflector moved aside, and I DO use expanded aluminum baffles at the door when under way.)
Greg and Linda Heuer
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 01-22-2014, 02:39 PM   #2
2011 31' Classic
Bump - Anyone?
Old 01-22-2014, 03:30 PM   #3
Wayward's Avatar
Cary , North Carolina
Should be a very tight fit. You could remove the ceramic, press the bracket lip tight in a vise or pliers, and try to reinsert. Or, epoxy it. Or get a new one.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-22-2014, 04:34 PM   #4
1977 Argosy 24
Milltown , Wisconsin
A dab of epoxy should do the trick. Just make sure the end of it is in the flame.
ventport is offline   Reply With Quote
