Old 11-21-2009, 08:42 PM   #15
Originally Posted by DavidsonOverlander View Post
What kind of copper tubing should be used for propane lines?
Are there special fittings?
Do compression fittings have to be used, or could the connections be soldered?
I'm replacing the whole lot on the Sovereign.
Grant
Soft copper tubing is fine.
Compression fittings for LPG lines should "NEVER" be used.
Flare type brass fittings are always used for the LPG lines.
And
Old 11-21-2009, 09:09 PM   #16
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by Mrwaterway View Post
Folks,
ANDY-since I have a 1972 axle on my Ambassador, is it possible that the torsion action could still actually work?
This is an article from Airstream.com on axles take a look here. http://service.airstream.com/files/l...22708290a0.pdf
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-21-2009, 10:20 PM   #17
Lee.
I wrote the vast majority of that article.
Airstream modified that article, adding to the errors that was in the original article.
As an example, the very last paragraph, is grossly incorrect, which I did not write.
Airstream has been advised of these errors, and the incorrect paragraph, and will have the entire article removed, corrected, and then republished.
I personally advised Airstream of the problems and they assure me that it would be corrected, but would take a while to accomplish that.
Since that article is still in their web site, I will ask them to remove it, until the necessary corrections have been made.
I suggest that links to that article not be made again, until the corrections have been made.
Further, Airstream did not ask me if they could copy what I wrote, which is another issue.
Old 11-22-2009, 04:31 AM   #18
1972 29' Ambassador
Fort McCoy , Florida
Images: 16
Underside Detached copper lines
Originally Posted by wkerfoot View Post
Why not use a strip of aluminum for the bracket with a piece of rubber against the line?
Bill
Good idea, I'll mess around and come up with a solution-right or wrong. Galvanic corrosion makes sense as the culprit WHICH I thought had a lot to do with electrical current-(as in Marinas), so the inert rubber or other object makes sense. The older Spartans keep all their propane lines inside-more dangerous perhaps, but less vulnerable. Each of my propane appliances have seperate T-valves-(cut-off), this includes the furnace, Dometic Fridge and the Hot water heater. The copper is old and swollen, but heavy duty. I will try and show my work with a picture or two-Thanks for all the sensible help suggestions.
Mrwaterway is offline   Reply With Quote
replacing gas lines bennobel Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-08-2009 06:37 PM
LP Gas Lines Silverhobby All Argosy Trailers 6 01-24-2008 09:25 PM
gas lines inside kamo LP Gas, Piping, Tanks & Regulators 5 11-06-2006 08:40 AM
gas lines scootertrash LP Gas, Piping, Tanks & Regulators 1 02-27-2003 10:00 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
