Old 09-28-2012, 07:12 AM   #1
2013 27' FB Classic
manchester , Michigan
Locking Aluminum LP tanks on a "Classic"
Any ideas or products that can be used to lock the 40lb. Aluminum LP tanks on newer Classic Limited trailers. If you fabricated a device do you have pictures? Commercial applications? Thank you!
brownm3 is offline   Reply With Quote
Old 09-28-2012, 07:21 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Sad to say, but locks only keep honest people out. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 09-28-2012, 07:56 AM   #3
dznf0g's Avatar
Oswego , Illinois
Sal is right...but.... I had an old Reese coupler lock, which was not that great of a coupler lock and was replaced with something beefier. I then that the bright idea that if I cut the "ball off of it, it would make a good propane lock.
-Rich-
Old 09-28-2012, 08:23 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Search here for propane tank lock. There was a discussion about this a while back. It has links and photos to several solutions. All are good to deter opportunity theft. Any can be defeated with time and tools.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 09-28-2012, 09:01 AM   #5
2010 27' FB Classic
N/A , Texas
Attachment 169120
That's a good idea dznfOg.
I lock mine by using a long plastic coated steel cable that I fish thru and along the bottles and around the frame and back again thru the openings in the bottles and loop it around the cover braces. I end up with a regular pad lock where both ends of the cable meet. A little more work but the price was right as I had the stuff laying around collecting dust.
"Thereís two kinds of people, them goiní somewhere and them goiní nowhere. Andís that whatís true". -Ben Rumson
Old 02-15-2013, 03:20 PM   #6
Joebanjo's Avatar
1976 29' Ambassador
Wichita , Kansas
Secure those aluminum tanks.
Agree with Bluto
I use a plastic coated cable (normally used to secure a bicycle to a telephone pole etc.) Simply snake the cable through the tanks, wrap around the tongue of the trailer and put on a pad lock. I also store my trailer at a commercial facility which is very secure....but I remove the tanks anyway and keep them at home..
Joebanjo is offline   Reply With Quote
Old 02-15-2013, 03:32 PM   #7
1974 Argosy 20
Kooskia , Idaho
I use the cable system also, and when gone in the winter, I put the tanks inside the AS and Argosy. The cable will not keep them really safe, but reduces opportunity theft situations when I camp in obscure Forest Service or NP campgrounds. AL tanks are now over $250 each, but probably would be taken for the propane only by most lo lifes. Any locking system will slow them down at least. With no lock, and the hand disconnect on the new POD valves I can have a tank off my rig in about 30 seconds. With a lock and key it takes me 2 minutes. Now, with cable cutters, back to 30 seconds, but not too many opportunity theft people carry the cable cutters with them.
Old 02-15-2013, 03:45 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
An elegant design..........Torklift.com | Home of Torklift International
Old 02-15-2013, 04:24 PM   #9
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Originally Posted by lewster View Post
Lew,
Do you know which size would work? 3/8 or 1/2? Trailer in storage right now so not able to go out and check.
chuck
Steamy1 is offline   Reply With Quote
Old 02-15-2013, 05:00 PM   #10
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
the other end...
if ya gotta lock 'em, drill a hole through the bottom flange of each bottle, and through (at a matching position, of course) the 1/8 steel figure 8 bottle mount welded to the tongue-then place a good lock through the holes. after a thief delicately removed the aluminum cover, then unscrewed the wing nut holding the bottles down, and removed the lp lines and then unsuccessfully tried to lift the first bottle out, then maybe he'd give up.
wmarsha is offline   Reply With Quote
Old 02-15-2013, 05:47 PM   #11
sweet.
dsrtgrls is offline   Reply With Quote
Old 02-15-2013, 07:31 PM   #12
lewster's Avatar
Originally Posted by Steamy1 View Post
Lew,
chuck
I'll check on Monday............
Old 03-22-2013, 09:25 PM   #13
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Lew,
Find an answer or price yet?
Bill
Just my personal opinion
Old 03-22-2013, 10:55 PM   #14
Mexray's Avatar
1978 28' Ambassador
Morada , California
I use one of these 'cheapo' lug nut locks on the top of threaded rod that attaches the clamping handle...You can find them at most any auto parts store for under $5...
I know it's not much of a 'real' deterrent, but might cause the casual thief to move on - or make him use a hack saw or chisel to get the tanks off...
I use one of the same locks on the exposed battery box behind the tanks, and on an attaching bolt of the spare tire holder...
I have also used the coated locking cable method when I feel especially vulnerable, using a special lock that can't be cut with bolt cutters...
Ray & Pat; Morada, CA
