01-09-2016, 09:24 AM
2016 30' Classic
Houston
Lock for LP Tanks
Getting my first AS at the end of the month. Can you recommend a lock for the LP tanks? Thanks.
01-09-2016, 10:03 AM
Retired.
, At Large
Just something to discourage would-be thieves, and keep people honest. Anything more elaborate would turn into more headaches for you in trying to remove your tanks for refilling, and someone really determined will still get them.
01-09-2016, 10:10 AM
1974 Argosy 20
Kooskia
, Idaho
I use a cable, like a bicycle lock cable with a padlock. As Overlander63 says, anything more makes them harder to get off to refill.
I have the expensive aluminum tanks. I am not sure it would be worth it with steel tanks.
01-09-2016, 10:20 AM
2013 30' Flying Cloud
Greenwood Village
On the Airstream shop site they have a specific screw down lock for the LP tanks.
01-09-2016, 10:38 AM
2008 27' International FB
Oklahoma City
, Oklahoma
I would second idroba, unless you have expensive tanks, I wouldn't lock them. We don't lock ours.
01-09-2016, 11:13 AM
Peterborough
, New Hampshire
Airstream has a clever lock which you can buy from their Ohio store.
01-09-2016, 11:20 AM
Alamo Heights
I use the same method idroba does, a cable run through the collars on my aluminum tanks and around a frame member, with a padlock. The cable is just a deterrent, of course, but I guess most of the dirtbags who'd steal such things want the propane and don't necessarily know what my 40-yr-old aluminum tanks are worth, so they'll steal tanks from one of the other RVs at the storage lot that don't have theirs locked.
— David
01-09-2016, 11:25 AM
Retired.
, At Large
Most people don't realize yet, the Classics have 40# aluminum tanks with built-in gauges. $$$...
01-09-2016, 11:29 AM
Taos
, New Mexico
I've taken all the pad locks off my trailer. I figured a) if someone wants something bad enough they will bring their own equipment to defeat a lock and probably damage the trailer in the process and b) if I'm out on a cold night on a dark road changing a tire or something I sure don't need a frozen up lock that I can't open. I asked about a hitch lock and my mechanic told me that if someone is in it far enough to steal a trailer that they don't even mess with the hitch locks they come prepared and some even just put a chain on it, lift it up, and off they go. I thought about a wheel lock / Denver Boot device but realized that I'd be the most likely one forget it was on there and snap an axle when I'm in a hurry one day go get going.
01-09-2016, 11:34 AM
2010 27' FB Classic
N/A
I still use the cable and lock method but I'm looking hard at this one that was mentioned on the following link.
http://www.airforums.com/forums/f48/...01729-250.html
It is mentioned on page 250 post 3495 to post 3499.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
01-09-2016, 12:51 PM
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Prescott Valley
I drilled a hole through the spin off handle and the cross brace on the tank cover. Then I installed a pad lock through the holes.
01-09-2016, 12:55 PM
1966 22' Safari
Hilltop Lakes
I've just put a nylon lock nut on top of Airstream's threaded handle to secure the tanks in place. At least it forces the thief to bring a wrench.
01-09-2016, 01:11 PM
2014 27' Flying Cloud
Stowe
, Vermont
We like our - TORK LIFT A7701 RV Trailer Camper Lp Gas Fortress Propane Gas Lock 3/8" by Torklift - Make sure to get the correct diameter for your threaded rod that the lock screws on to.
01-09-2016, 01:58 PM
1994 34' Excella
San Antonio
I always remove the tanks when in storage and use them for our home grill. Those tanks have been re-certified a couple of times! Oh well, good luck! jd
01-09-2016, 03:09 PM
belen
, New Mexico
I used to keep my spare right there and would cable lock it and my tall aluminum tanks all together!
01-09-2016, 04:12 PM
2006 19' Safari SE
Tucson
We use this handle little lock... It's not fool proof but it will make them work for it it...
Unfortunately, for the life of me I can't remember where I got it!
You can also Google "Propane Tank Lock" and find some ideas/products.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
01-09-2016, 04:37 PM
So how common is tank theft?
Is this a frequent problem? Does it generally happen in camp grounds or in outside storage lots?
01-09-2016, 05:37 PM
Biloxi
, Mississippi
Personally I have never heard of a case of tanks being stolen but I suppose anything is possible.
MICHAEL
01-09-2016, 06:31 PM
Alamo Heights
Most cases of propane bottle theft I've heard of have generally been rural areas and the theory is that the thieves are using the tanks to store anhydrous ammonia they steal to make meth. Late last year I heard about a bunch of tanks stolen from those vending racks around Kansas City, I think (some midwestern city I'm sure, KC I'm less certain about.)
— David
01-09-2016, 07:59 PM
1974 Argosy 20
Kooskia
, Idaho
We in Idaho who camp very rural and boondock a lot need to be somewhat careful of the hunters who use old RV's for their hunting camps. They run out of propane and look for a source which does not involve going 50 miles to town for a refill.
Certainly not common, but it does happen now and then.
